Tiger 1, Initial (sPzAbt 501/‘DAK’)
The second build of this run will incorporate items from Dragon 6252, Tiger 1 Initial Production, Leningrad 1943 and necessary supplements from the Tamiya ‘DAK’ Tiger 1 kit. My initial plan was to use the Tamiya kit wholly, but on inspection that kit has an incorrect engine deck configuration and will lends itself better to a later Tiger in the production run (I will use this for the David Parker 1943 sPzAbt 502 Doppleganger Tiger). There will be a styrene DAK-style turret bin on this build. This Tiger was produced in the autumn of 1942 (September) and was one of the first 20 of the production run. You will recognise the Initial Tiger 1 features throughout this build, but will also spot the obvious upgrades.
Principally the popular concept of a DAK Tiger was an initial Tiger 1 with some embellishment. There were subtle differences between many of the DAK Tigers, but this one will represent one of the earliest arrivals in Tunisia, having been received by the sPzAbt 501 and then later passed over to the 10 Pz Div in North Africa. Looking at later DAK Tigers they look very similar to the classic ‘Early’ Tiger 1, with few identifiable DAK features, but with this build I hope to encapsulate the distilled DAK version. Having spent time looking for the right Tiger 1, Afrika I have come to the conclusion that Tiger 112, later 812 and finally 712 (same Tiger, different tac numbers under different companies/Abteilungen) is the correct AFV to build; an Initial Tiger 1 with back-to-front tow ropes, sloped fenders and all the trimmings (that I can see). Some of the additions may be incorrect, but I will throw the DAK book at this tank and hope to give it the number 112, which will represent Fgst 250012, which is just a pigeon step away from the last build, but will have a number of differences, albeit superficial.
Features of this build will include;
Tiger 1early 88mm barrel
Initial style gun mantlet
Asymmetrical turret rear pistol ports
DAK style turret bin (different to the later production version)
Unique DAK-style louvered exhaust shrouds
Spare track carriage at the bottom of the rear plate
The first application of all left-hand run Tiger 1, early tracks
Reverse tow cable stowage
Unique track cable stowage
Ranging vane on the turret
Flappers on the exhaust
Initial style crank starter mount
Second style tow U-hooks (rounded shanks)
Early-style Feifel and apparatus
Glacis mounted twin Bosch lights
DAK-style round-edged rear mudguards
Angulated fender runs on both sides
Rear plate mounted tool box
Camouflage loops introduced
Rear plate reflector (absent in the first build)
This project will use the following items;
• PzKpfwVI Ausf E SdKfz 181, Tiger 1 Initial Production, ref 6252
• Tamiya DAK Tiger, ref 6252 for specific DAK spares
• Friul Tiger 1 Early tracks
• Voyager Model DAK Tiger 1 for Tamiya PE set, ref 35227
• Armorscale 8.8cm KwK 36 L/56 Tiger I barrel & resin mantlet (early model), ref
• Aber MG 34 machine gun tips barrel for turret mount, ref 35L83
• Aber Barrel for German Tank MG 34 machine guns, ref 35L63
• RB Models turned brass antenna, ref 35A02
• Voyager Model Feifel hoses
• Aber 15t jack
Items to be used from the Tamiya DAK Tiger;
• Turret bin
• Early design Feifel
• Rear plate tool box
I shall also have to raid the spares box for a number of items along the way.
The final finish of the kit will include base-colour tactical number (112) with white outlines on left and right aspects of the turret. I suspect that this build will be more of a challenge than the last one.
Bill
http://panzersinscale.blogspot.com/
