HI All,
A quick update:
I have finally finished the steering arms, believe it or not it took me three evenings to complete this. Well its done
Ok. I mentioned that I was condidering using the Dragon hull inplace of the Tristar hull, well lets look at the pros and cons of each.
Pros
1) The Tristar hull as a good level of detail on the hull sides and lower hull. It has correctly placed bolt details and the two access hatches in the lower hull floor.
2) The Dragon hull has fully assessembled hull sides - as basic as it sounds this is an advantage.
Cons
1) The Tristar Kit hull and lower hull do not join up together flush, there gaps. These will require significant time to make right and in the process I might loose some of the bolt head detail that I like and I may end up having to replace the lot.
Also I am concerned about the strength of the hull. I will be adding heavy lead tracks and a brass superstructure and turret, will the weight cause the hull to fall apart? I doubt it but I cant be sure.
2) The Dragon Hull is in one piece and lacks the fit and strength problems of the Tristar hull. I have just finished a PanzerJager 1 with heavy lead tracks and a brass superstructure hull, it strong enough.
On the otherhand the dragon hull has no internal details and 6 ejector pin marks. I had to add over 100 bolt heads in the Panzerjager 1 and I am not that keen on having to do it again.
Moreover the Aber parts were designed to a Tristar hull, there may be unforseen build problems later on.
I have to make my mind up soon as my indecision is holding up the build what do you all think???
Thanks
Steven
