The first thing I'd like to say I'm trying to get better shots. So far I'm using a pretty old camera, so I'm doing the best I can. If anyone has some ideas for improvement, please speak up. I just made a simple light-box and this is what I'll be using through this blog.
I won't be following the steps indicated in the instructions but build in modules, so I can figure out what works best. I will be following the part sequence however by the instructions.
This is what I made first. I'm very happy to say the fit is great. The errors in the kit will be mentioned in the inbox review coming soon, but for now let's repeat. The thread pattern is wrong and the lettering is off due to copyrights? but the concept of 3 part per tire is great, no puttying is necessary and everything lines up neatly.
I just snapped the hood of the sprue to show the nice framing on the inner side. It's a welcome sight if you want to model this open.
Next in line is something with more work. The chassis frame has a seam line all the way long and a couple of sink marks that needs taking care of prior of adding more parts. I used a handful of Mr.Dissolving Putty to fill the sink marks, and will sand everything when it cures. To remove the seam line, just run the scalpel along the plastic and with a few quick swipes, it's done
The lower body has nice detail all over. There are some holes that need to be drilled out and you can start adding some parts soon. I added the side armor plating, floor covers and the radiator as these won't hinder any painting or building that will occur later.
The big parts go pretty easy here. I added the roof padding? and some parts like the turret ring. Also I've started the smoke discharger assembly. The fit here is good as well, but I do have some issues about the smoke dischargers - the exact position is kind of a mystery as the instructions give a vague picture and no locating points what so ever to place them. I placed these two according to some pics on the web. I saw some overhang the roof a bit so I went for that style.
Speaking of the roof, I also took a shot of the turret. Its pretty straightforward affair, but is on the small side. I have Legends GPK turret and it's wider than the kit offering but this one looks ok to me. I don't have the exact measures of the real thing so this is coming off from looking at random pics on the web. The fit of the armor plates on the turret is actually good, but I hacked off some plastic while sanding, so I'll need to use filler on some places
One thing I picked up here. I've read the instructions are wrong on the first step and want you to place the back axle on the front. I assembled the (rear) axle and labeled it with a marker to know what goes where.
So, later I'll see how everything fits on the frame. So much for now.
>cheers
