Amazing work and detailing! So, would you recommend Voyagers PE-SET to tackle trumpeters kit?
Thanks for the inspiration,
Andreas
Hi Aaron!
Yes the spare tracks...... that was a briliant question, and the answer so simple..... I don't have an ideaI think it's welded one, couse if you see the photo you can see that the spare track's midle where are the driver spikes it's under the barrier! So I think I will glue it somehow, ot I will soldering!? we will see. By the way, that wont be tomorrow
Cheers: Gergo
two things:
still cant tell from the resin kit how they where attached in real life.
also t-72 tracks, are they not "live" tracks? that curl up if they are not under tension? can you use them as additional armor if they do that?
Well Gergo, if they are the same, you should use the friul tracks on the wheels and trumpeter tracks to depict the extra armour. Unfortunately I don't think there are enough links in friul box to depict both.This could be probably the easiest and the cheapest solution
Love friuls, one of my favorite parts of armor building
couse i have a very good contact with..... secret
I build only 1 model in 1 year, than the price is not too bad isn't it!
