Happy Modeling, -zon
Hi Paul,
Yes, tree stumps might well be the way to go.
I did a little more work on the left hand trench, lowered it down a bit and made it into a weapons pit for some kind of weapon as yet unknown.
Also added some paint and mud to get an idea of what it might look like overall, alwasy hard to tell when evrything is a bit bitty.
I can see where it's going now more clearly so I can think about individual bits and adding some detail.
Al
Hi Alan,
Your diorama is coming along fabulously. If you keep adding to it, you'll be at the Swiss border in no time. A suggestion from my own area of expertise regarding the timbering in your tunnel. The transverse horizontal pieces (miners call them caps) which rest atop the posts should have shallow notches at the ends to keep the posts in place and the bases of the posts should be spread outward slightly to help brace the timber set. You also want longitudinal horizontal braces between the tops of each timber set, and they should butt against both cap and post, to keep the caps from being dislodged. This is particularly important in an area subject to concussion from artillery bombardment. If the ground is loose, you would have lagging, usually planks or small poles, possibly corrugated sheet metal, above the caps to keep dirt from falling in.
Another thing is that tunneling generates an enormous quantity of waste (spoil) which has to be disposed of. I'm not sure what sort of ground underlay the Somme battlefield, but I know that in Flanders, they tunneled through beds of chalk, the same beds which form the white cliffs of Dover. An alert aerial observer seeing a quantity of white chalk appear on the surface around a trench would immediately conclude that tunneling was underway, and steps would be taken to counter it.
Looking forward to seeing the final product.![]()
Dick
