Little advance of the evening!
I mounted the 2 hatches. As I assemble the model, I confirm that the quality of the molding of the modern models (at least this one) makes that the PE becomes less and less useful. Or that I wouldn't be able to mount it well enough compared to plastic parts. So, as you can see, there aren't many. Example with the part of the part circled in red. Normally, I have the cross-shaped piece with 3 branches to put under the opening steering wheel. I might have a better rendering of this part, but I will not succeed in reproducing the nuts as well as the part you can see ... Suddenly, I would have a less good overall rendering I think. A well-made wash should also greatly reduce the lack of relief that the PE piece would have made.
I also mounted the panoramic camera. Same thinking as before. I find the assembly I had made with the Tamiya piece and PE less convincing than the Border Model cam. More detailed, more precise than what I had managed to do ... The small parts which return in front of the glazed part is practically as fine as the PE. And I will eventually be able to thin it by sanding it ... To make the anti-reflection treatment, I got AFV club stickers which give good results. Despite everything, what I had done previously on the Tamiya cam, I found it too present. Not easy to take a picture, normally it's more or less pink / blue / yellow like I did in one of the photos I made at the time. So, I painted the inside of the cam in black and put the sticker on the bottom. Well, I should have also put it on the lower part but I'm not going to reopen it for that ... The fact of having put it at the bottom makes the result less flashy and we only see it under certain angles. In some cases, we see that it is black as in real. Curiously, Bordel Model did not try to reproduce the plate engraved on the back of the support of the cam ... So I added the small piece in PE. The assembly of the parts is super precise, I did not retouch anything. You have to make blank montages to understand how they go with each other.
Overall, I am more satisfied with the result than what I had done on the old camera. What do you think?
->> TOM: oh, un cousin québécois!! je te réponds ici mais si tu veux, tu peux venir sur le site francophone Maquette Garden, ce sera plus pratique pour plus de détails. Néanmoins, comme je le dis, les pièces du kit sont globalement meilleures que les mièces en PE et même en résine. Je sélectionne donc au cas par cas les pièces qui me semblent meilleures.
https://maquette-garden.forumactif.com/t21681-leopard-2-a6-can-afghanistan
