It has been awhile since I have posted an up date. Between doing a lot of History teaching and things like a short in the home AC unit,I haven't been at the work table as much.The head gardener also keeps me busy as out side this is prime gardening/planting weather. Low to upper 70s. Later it gets too hot.
I would like to say something to all of you. I feel very what ok unskilled. I see what everyone posts and my work s just not as good.You guys do great work. Artists. Somewhere in the bowels of my K-5e something is glued slightly off. That plus my gluing the plastic trunions (kit trunions) then having to gouge them out and use some brass rod for trunions,well diameters etc are a tiny bit off.OK wonky!Add it up and the trunions are off. I uses 5 min epoxy to glue the trunions to the base. The gun is not permantly in a 50 degree position(the actual gun used 50 degrees for max range.Then I test fitted the trunion caps and ,oooops. they don't cover the brass tube(remember it;s diam is a bit bigger than the original. So using the epoxy(for strength) I glued some strip material to fill the gap. I will glue the trunion caps on later.
When I used brute strength to make the trunions fit into the holder 2 things happened. On 1 side the deck broke free and opened a gap. On the other side the trunion mount broke free of the deck,I epoxied the deck gap and I will epoxy the other trunion mount today. The good news and the bad. The good is I test fitted the metal barrel and everything held so it is going to work.,plus it looks really gig and spectacular!To my eyes at least.The only negative is the breech,where I did a really good job is completely hidden. But hey I know it is there!
The bad is it will not fit on the shelf I initially planned on displaying it.So it goes on the top shelf of the display.
Once I glue(epoxy) the gun to the deck I will finish up the crane the generator , sights(panoramic telescope.) ets.
I wish one of the references would show/describe the placement and use of the aiming stakes,The German survey methods etc. The gunnery aspects. It must be similar to my old M-107 175mm gun. Rotation of the earth etc. I do know the preheated their powder to get max muzzle velocity.Also they had to have been really careful laying tracks due to barrel cant. Remember these were not precision weapons. they were very accurate area weapons.For example the targets would be rail yards,airfields etc.
I know most of you enter model contests etc. My efforts pale in comparison.I am doing my best.I think it will look good enough for any who come to my house.
At the very least they will say that is huge what is it. They won't see the trunion errors etc.
Finally I found a product it is PERFECT PLASTIC PUTTY made by deluxematerials.com I bought it on e-bay about $10 price plus shipping from England. I like it because it is easy to use and after being applied I moisten my finger(spit) and it can be cleaned and smoothed. When you make as many mistakes as I do ,it is handy! I just discovered the US distributor is Horizon hobby in Il. horizonhobby .com
Next hurdle is applying the rotbrun option of the camouflage scheme.
Attached are pictures of the build up to today 30 April 2013.
