Gentlemen,
I had a few hours for the hobby this weekend, and here are the results:
First I applied the decals -- as simple as they get -- depicting a 3.Zug, 5.Leichte Division vehicle. No pictures were taken at this point as it was just decals on the previously presented tank.
Then I moved (perhaps a bit too fast, later will tell why) on to the painting again. I airbrushed gradually several thin layers of light color to simulate the heavy dusting in the Western Desert which the vehicles accumulated fast. I used again my favorite Tamiya acrylics, this time in the very light range: Buff, Deck Tan, Desert Yellow 50/50 mix with White, and at the end, even a bit of pure White.
This gave me the effect I was after in terms of merging the decals into the vehicle, and also significantly reduced the contrast between the dark and light paint. I added manually just a little additional chipping here and there to represent very "fresh" damage on the paint -- which shouldn't be that big given the rapid dusting up.
And here's the problem I noticed: apparently I didn't wait long enough for Gunze's Decal setting solution to dry up enough, and the 5. Leichte insignia on the turret bin (the stroked through D) decal bulged up a bit under the paint. I hope it'll settle down when left alone for a while. If not, I'll figure out a solution.
Then, I proceeded with the basic wash. I used AK's DAK Vehicle wash and went over the whole vehicle. I cleaned up most of the spillage, and now I am giving it a couple of days to tighten up and touch it a bit additionally with some white spirit for modulation if needed.
Finally, for literally 5 minutes I made a quick test run of some additional color modulation using Oil paints -- the dot technique as it is known. The results can be seen on the turret top and on the top of the turret bin. I didn't want to continue any further with it at this point as it would mess up the wash. Hopefully next weekend
Also, with Oil paint I added a slightly darker yellow-reddish color right under the mud guards as a starting point for some slightly darker streaking.
So this is it so far. The paint looks a bit rough at a few places -- either because of the HS technique or because my airbrush spat out a few thicker dots. Once fully dry, I'll treat these areas with a very fine file or sanding paper to even these out.
And now some pictures:
Next steps would be also including some more play with color (Oils and dot technique), and some serious use of filters.
Thanks a lot for your time and attention! And have a very nice and successful week!
Ivan
P.S.: The controversial turret hook is back in place
P.P.S.: I didn't deal with the sink marks on the gun mask yet. I have very limited time lately for modeling, and had I addressed these yesterday, I wouldn't have been able to do as much work as I actually did. I'll try to squeeze 10-15 min during the week for them so that I'll have more time to paint retouch in the weekend.
