Well....I think the construction is done! Things will be moving to the booth soon. I will be showing some of the painting process but the bulk will be saved for the feature for Armorama...but then again, I will have the dio to construct too...so plenty of pics to go around!! Forward...
The blade!!
This was straight forward, clean up some parts and they fall together. There are two shield type cover plates on the rear of the blade. The instructions show them being installed in two slots...they didn't want to fit with the tab...I found it just easier to remove the tabs and glue the suckers on!
With a sharp eye, you will see two EPM's on the top two inside plates of the blade...fill....sand...gone. After this blade came together, it was just a matter of sticking the pieces together.
I think it is a rather impressive looking model all around. In the next pic you will see a couple of things that look out of place...one being the white handle on the cab mount. This part was broken in half in the kit. Tinny bugger, I could not find the other half. I made one in a few minutes with some rod stock, sanded the bottom flat and a couple bolts and I was back on track. The other is the fuel cans. These are not the ones from the set. Now I have not heard any issues with the cans fitting in this part anywhere online...but they were a touch small. Since I have the Black Dog IDF Accessories Set, I have two fuels cans that fit superbly in the PE rack.
Moving to the top, I wanted to add some of the Basalt anti-skid effects. This looks not too bad up close but is a bit heavy at the moment but I am waiting until completely dry and I will scrub this back a little. I used Cinnamon. The granules are spot on for the scale I think. After looking over some of the pretty pictures in the Dessert Eagle Book, D9 Variants, there are several pics of the topside. They are from two different D9's. It is clear the application is installers' choice as to where the coverage goes....
So that covers 99.8% of the build. I have the blade's horizontal stabilizer to install which get a cap that glues on...if it goes on now, I will not be able to remove the blade for painting.
I had to give some of the BD IDF Set a little dry fit.....
I have a ton to choose from with the set, so there is a few other pieces and I will mix and mingle them to get something that looks decent.
A little raised blade action for the last shot....
So there you have it, construction done! I do have one handle to add to the cabin door that I missed. Other than that...time to prep this big girls for some Primer!!! Wish me luck!!
As always, thanks for hanging out!!
