Hi Phil,
Thanks. I have been looking at different photos and Tthe Syrian T-72 AVs seem to have a mixture of both wheels. It seems to be dependent on the how early the T-72 was produced and battle use.
T-72 with early fenders (early wheels, in some photos mixture of both early and late wheels)
photo for discussion purpose, taken from site
http://bmpd.livejournal.com/489801.html#cutid1T-72 with late fenders (late wheels)
http://milinme.wordpress.com/2013/01/10/I will be buying later on a late T-72 wheel set and will be using some wheels; I will be using the rest in another project.
In other things, I have been trying to find photos of the KMT mounts on Syrian T-72AVs. Export versions have fewer number of mounts than the Russian ones which the Miniarm represent. Although it will be covered by ERA, you may want to double check, as it may affect slightly the angle created when they are mounted (first row, top to bottom, on top the KMT mounts), which may be noticeable when compared to the row next to it.
This seems to be version you are modeling, correct me if I am wrong
http://milinme.wordpress.com/2013/01/27/syrian-t-72av-2/Have you had any thoughts of what color are you going to paint the beast? Green or desert sand?
Best Regards,
Raul
