The first you can see is the use of spacers. This is because a space is needed for the ERA explosion to disrupts the HEAT jet successfully.
Hi Phil,
This statement is bothering me. Sorry that I made it and can't support it. What I can quote for discussion purposes only and I hope Steven Zaloga doesn't get mad at me.
"The Soviet EDZ differs from the Israeli Blazer type in a number of respects and works as follows. When the HEAT warhead detonates against the EDZ brick, the hypervelocity jet of metal particles from the warhead penetrates the brick and detonates a thin sheet of high explosive. This explosion propels two steel plates located on either side of the explosive sheet. The outward facing plate is blown up into the penetrating jet, eroding the metal stream by forcing more and more metal plate into the path of the jet. At the same time, the other plate is propelled back towards the tank armour by the explosion, then rebounds off the tank's armour up into the remaining stream of the warhead jet, further eroding it" Zaloga,S. J. "T-72 Main Battle Tank 1974-93", Osprey Publishing
Sorry I can't find more information about the space at the moment.
Best Regards,
Raul
