A little bit of detail type stuff for the Heinrich bay:
I decided to give the back wall some "shape" by angling it. No other reason than it looks better than a rectangle.
Most of what will go in there will be spares box parts (the two rectangle parts on the upper left are from a Dragon BTR-80 I think, the tan box is a toolbox from a 1/24 Ranchero), a mix of copper, aluminum, and styrene tube for piping, and some scratch work.
Primed with hooks on the back left wall for chain, three doors (one on each side - to access crew compartments battle positions(?) and one to access the "storage area" between the two Heinrich bays). I also scratched a quick workbench. Not sure what else will go in there as it's just tall and wide enough to accept a Heinrich.
Because this will "slide" into the track housing, I can't have anything sticking out from the sides, top, or bottom; so I'm trying to figure out how to put six tie-downs on the floor. I can't really recess them unless I drill the holes and line the bottom of the holes with some .005" brass sheet. If I do that, then I can scratch some hooks for the chain tie-downs.
And I still need to come up with a ramp lifting system...thinking something very much like an M113/M577 pully system.
(borrowed from panzer-modell.de FOR DISCUSSION PURPOSES ONLY)
Mike
