KitMaker: 3,770 posts
Armorama: 2,263 posts
Posted: Sunday, August 03, 2014 - 08:47 AM UTC
The other track housing is partially assembled. The two together are 8 inches across (
And I received word from Oz Armour that the other half to my wheel sets have arrived. Hope to hear soon that they're on the way to me.
Mike
KitMaker: 1,624 posts
Armorama: 994 posts
Posted: Monday, August 04, 2014 - 04:17 AM UTC
Hey Mike,
Dang, getting to be a hand full. Hope those wheel get here soon.
Looking good.
See ya in the funnies...........
Everyday is a gift, not a given.
......and all we know is he's called the Stig.
Posted: Thursday, August 07, 2014 - 02:22 PM UTC
Quick update.
Closing off the ends of the track housings. Then to drill the holes for the axles.
After that? Time to figure out the front, back, belly, and roof. (basically its width)
Mike
Armorama: 994 posts
Posted: Thursday, August 07, 2014 - 05:07 PM UTC
Mike,
Sweet. PM sent. I'll check for reply in the morning.
See ya in the funnies...................
Posted: Wednesday, August 20, 2014 - 01:16 PM UTC
Sanded and scraped the front and rear of each track housing to level things out. I then started the layout for the belly, top, and front and back:
Figured I'd rough it on top of the bench. It's amazing how much larger it seems now (the bench is 5 feet across with the end tray on it):
The turret still gets raised up about 1 inch.
Oh boy.....
Mike
KitMaker: 2,210 posts
Armorama: 1,712 posts
Posted: Wednesday, August 20, 2014 - 03:29 PM UTC
Great gobules of sheet styrene plastic and glue Batman! That thing is huge! Good luck my man..
I do some 3D design work. Message me for more info on what I'm doing or have done. Inquire about a product catalog.
Armorama: 994 posts
Posted: Wednesday, August 20, 2014 - 06:42 PM UTC
Damn
KitMaker: 568 posts
Armorama: 561 posts
Posted: Wednesday, August 20, 2014 - 07:48 PM UTC
Proper job
are you texturing that plastic?
On the bench: Dragon flakvierling with armoured cab + AM Works PE
In the stash: Dragon Jagdpanther + AM Works PE
Dragon Panzer IV Ausf J + voyager jumbo PE
Tamiya B2 Bis - Flammenwerfer mod
ICM Henschel 33D1 + Dragon sFH18
Tamiya Tiger 1
Posted: Wednesday, August 20, 2014 - 11:15 PM UTC
Up until your comment, I hadn't given that much thought Andy. I do need to though. That's a lot of Mr. Surfacer! So, short answer - yes, I will.
The way it's sitting on the bench it's 16 inches wide. From the dimensions I was able to pull from various sources, it's 1/4 inch wider than called for. I may or may not need that 1/4 inch. The turret will be sitting on an angled platform that will meld with the glacis and go over a portion of the track housings. I need room on the left and right for a walkway from front to the rear beside the turret. If I don't need that 1/4 inch, it'll be narrower.
I think what's really up next is to rough out the glacis and then put some Bondo on the tops, fronts, and backs of the housings to true up the edges. With the glacis figured, I can finalize the placement of the MAUS' and Kugels in relation to the turret.
Mike
Posted: Tuesday, August 26, 2014 - 12:37 PM UTC
Well, the layout (support strips) for the belly, top, front and back are on both halves and drying. Harder to get the angles aligned than I thought, but once sitting on each other face to face, they look pretty good.
Emailed my supplier for the wheels this evening. Hope to hear good news soon.
And...may need some more 1/8th sheet stock. This beastie is gobbling it up pretty good.
More to follow.
Mike
Armorama: 994 posts
Posted: Tuesday, August 26, 2014 - 04:55 PM UTC
Plastimonster.
Hope you get them wheels soon.
Napoli, Italy
KitMaker: 652 posts
Armorama: 600 posts
Posted: Sunday, August 31, 2014 - 10:14 PM UTC
Mike, this is great. Go ahead !
Giovanni
Posted: Monday, September 01, 2014 - 03:34 AM UTC
Wheels arrived!!! Whew!
I picked up an attachment for my Dremel/Craftsman rotary tool; the Ratte will get some lines scribed showing the multi-plate armor on the sides.
If the fence I need to work on doesn't get in the way of bench time, I plan to use some scrap to get the two track housings set to the proper width and start laying out the front, back, top and bottom...starting with the bottom. The hard part of this is that it will be it's full length and width which means...big...which means I need to rig up something I can put it on and have access to all sides. Like a Lazy-Susan on a tall base; my bench won't cut it.
Anyhow, the bottom will consist of (initially) just a flat plate of 1/8th sheet. Then I'll build the angled runs that'll hided the nuts/washers/threaded rod for the axles. It'll probably be one of the last things installed before paint. I plan to put various engine access panels and a few "escape" hatches there too.
Mike
Oklahoma, United States
KitMaker: 796 posts
Armorama: 574 posts
Posted: Monday, September 01, 2014 - 07:00 AM UTC
See if you can find a tall bar stool at a garage sale and make a lazy susan out of it.
"Don't get stuck thinking inside the box."
Posted: Monday, September 01, 2014 - 07:49 AM UTC
We're thinking alike!
I have a Craftsman bar stool I can "borrow" for this purpose. I'll remove the seat and put a piece of ply on temporarily.
Mike
Posted: Sunday, September 07, 2014 - 12:51 PM UTC
I've started the basic assembly. The two track housings are together with "inserts" to get the proper spacing. I've also started "closing off" the bottom of the rear panel. Once I cut it out I can start the exhausts/spare road wheels/spare track layout.
The tan plastic is the template for the engine deck. I'm thinking of a combination of Panther and Tiger "venting" (of which I have both on the shelf). I'll get real serious about casting a few when I have some funds.
Mike
Napier, New Zealand
KitMaker: 1,049 posts
Armorama: 841 posts
Posted: Sunday, September 07, 2014 - 01:11 PM UTC
This is a project of epic proportions lol Great stuff !!!
Brent
Available for commissions,visit my Flickr Albums and modelling/painting blog to discuss .......
http://houseofqueeg.wordpress.com/
https://www.flickr.com/photos/134514258@N04/albums
Armorama: 994 posts
Posted: Sunday, September 07, 2014 - 05:09 PM UTC
Hey Mike,
It's coming along nicely. I take it tracks and wheels are next on the list for install?
I wonder how many gallons of glue its taken so far?
Oregon, United States
KitMaker: 520 posts
Armorama: 516 posts
Posted: Sunday, September 07, 2014 - 07:54 PM UTC
gallons of glue
not sure if Anyone could keep track at this point...
wow, the fumes....(hope he doesn't set his neighbors water heater on fire)....LOL
Life,, IS, unfortunately...
measured by the number of breaths we take,
but the moments that take our breath away,
are the moments that we wish;.,.,
Eternity remembers Of us.
Posted: Friday, September 12, 2014 - 12:26 PM UTC
Oddly enough, I've only used one squeeze bottle of Revell glue, 1/4 of a Tamiya thin, and maybe an eighth of a tube of glue. The Tamiya usually gets me dopey.
I know this is early in the project, but I'm considering two paint jobs for the main body (and may mix up the 6 turrets at the rear with same or different camo).
The first consideration (borrowed from Mig J):
The second consideration (which I like better):
Thoughts? Very much open to suggestions. Four Kugelblitz turrets, two MAUS turrets, one Battleship turret, and of course the main body.
Mike
Posted: Friday, September 12, 2014 - 01:59 PM UTC
IMHO, I'd say paint the body one of those camouflages', the battleship turret as if it just came off of the ship (so what ever color the Kriegsmarine painted their battle ship turrets), the Maus turrets painted that primer red color, and the Kugelblitz's maybe another camouflage scheme. I wouldn't doubt if the painters mustve used up the entire stock of Germany's paints by the time they finished painting the body of this beast.
Armorama: 994 posts
Posted: Friday, September 12, 2014 - 04:43 PM UTC
Hey Mike,
How about combining both camo's into one, after all it is a "what if" build and paint job.
Just a thought.
See ya in the funnies....................
KitMaker: 1,330 posts
Armorama: 1,017 posts
Posted: Friday, September 12, 2014 - 08:14 PM UTC
Another thing to consider would be to divide to standard cammo at the bottom and the upper half more of a sky type thing! It may help to disguise the height a bit!
KitMaker: 568 posts
Armorama: 561 posts
Posted: Saturday, September 13, 2014 - 06:31 AM UTC
Personally I would give considerable thought to the size of the camouflage pattern, esp for an ambush style. Do you keep it exactly the same size as it would be on a KT for example, or do you upscale it to a pattern 10x bigger? I'm not sure anyone has ever actually considered that as the variation in size between different vehicles is usually relatively small.
You could always argue a Von Richtoffen and paint it red so as to be seen and feared? ;-)
Tamiya Tiger 1
CMOT
Editor-in-ChiefEngland - South West, United Kingdom
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Saturday, September 13, 2014 - 07:24 AM UTC
Something this model has made me think about; If they had built this vehicle, how would it have defended itself with the limited gun depression. Any armoured vehicle even at a reasonable range could not be engaged due to the height of the main gun and secondary armament. You would end up with the equivalent of an aircraft carrier needing a battle group to defend it. Impressive build none the less.
