I've been taking my time with the Hobby Boss LVTP-7 in Argentinian Markings. It's got a pretty nice interior and I want to get it right. Anyway, blah, blah, blah...update time.
I got things rolling with the road-wheels, drive sprockets, and idler wheels. Pretty standard assembly. I did go ahead and prepaint the insides of the wheels with green.
Jet thruster units...parts and then assembled. Definitely a long way from Academy's old LVTP-7.
Suspension arms and the drive shaft and driveshaft guard for the jet thruster units.
I decided to go ahead and pre-paint the lower hull and wheels.
Out of paint. Added the front headlights. HB does this with a recessed insert and the lights are individually molded. Adding the lights is a bit fiddly.
Stepped back to work on the tracks. They are individual track links with separately molded rubber pads. They require a bit of cleanup. I staged out clean-up and assembly over a couple nights. The links appear to be semi-workable as they can click together. I'm not sure how well they'll stay together without cement.
Road-wheels painted up and mounted. Also added the thruster units guards. Those shaft units won't really be noticed once the outer cover pieces are added.
Time to start on the interior. I decided to pre-assemble a lot of the interior and paint as much of it as possible before installing them in to the hull. I dry-fitted the parts and some will require some work to fit.
And that's where I am now. I'll probably start with a base coat on the interior tonight or tomorrow.
