Well, all major construction is complete. PE is on. All that this kit needs is some paint. So I guess that does it for this build.
Speaking of the PE parts, in the instructions they are labeled "MA".
When doing the rear deck for the gun cradle if your going to do it in the stored position, or in the assembled position like I've, take care installing MA5, MA8. MA4 and MA7 go with MA8 and MA5. MA4 is very tiny and if you lose it to the carpet monster, well, good luck with that. MA7 is a bit larger, but you'll still have a hard time finding it if it is dropped.
Note here is that there are x2 MA5's to install. I've missed one which you'll see in the photo's below and its in the wrong position, this should placed higher up. Builder error on that one.
Now, on to the .50 cal., M2HB install. This is Step 13. Note the "after thought" window box, showing part J17, the M2HB. Note the blue areas to be removed.
These parts are for when the M2HB is placed on the tripod and are not needed.
Take care in removing them and make sure you remove the tripod pintle so it is level with the bottom of receiver.
The pintle and cradle set up seem to be the D80030 (6580030) mount. Source link is below:
http://www.usarmymodels.com/ARTICLES/MG%20Mounts/MGmounts%20page%208%20D80030.html
After you remove the pintle, you'll have to make sure it fits nicely into the front notch on the PE cradle or the M2 will sit funny and the rear will not line up with the rest of the cradle.
Note: What wrong with the photo above? Ummm, Part J23 is not sitting right, simple fix, give it a small shave. (See photo below.)
Now we fit just fine.
For you M2HB guys, note here also, Dragon has put the charge handle onto the receiver cover, part J23. So if that is something you what to correct, add an aftermarket M2HB.
So here it is, naked as a jaybird.
Thanks to Staff_Jim and CMOT for the chance to build this kit. I'm very humbled.
Final thoughts on the kit:
Overall, this is not a bad kit out of the box. Sure it has had its hiccups and needed a bit of hacking on the rear deck exhaust to make the turret clear and turn, but other then that, its a good kit.
Easy to build, instruction are typical Dragon, some areas easy to follow, some areas are not.
Part sprues are clean, little to no flashing. However, you'll have a lot of leftovers after the build.
Tracks are easy to assemble, no melting them together, just glue them together.
Wow, this is a long post. I'll continue after this little break.
Till then.......See ya in the funnies..........
