Evening fellas,
Just a few quick updates. Been making good progress, but have not been taking as many photos since I'm trying to cram in bench time here and there in small increments. I finished painting the M1 steel pots, well, almost all of them.
Here's the "prisoner's" pot. I used a rust color to replicate the subtle pattern of the fiberglass liner. After seeing the photo, will probably hit the webbing brace with a pin wash.
And here's one of the paratrooper's helmets. I used the Archer helmet insignia set for the 502 PIR heart. I used yellow, cream, green, and grey oils in a "dot filter" method to achieve to depth and richness to the finish. Pretty happy with the way it turned out.
And here's the other paratrooper's helmet. This was actually my second attempt at the netting. The first go around, I actually finished the helmet just like the other one, painting, insignia, etc. Then, plan was to use fine wedding tulle (basically veil material) painted light green, and then stretched over the completed helmet. The tulle turned out to be too stiff, which made it hard to tuck and glue on the inside rim of the helmet. So had to scrap that approach. I read somewhere else on Armorama about using panty hose. So, after the awkward conversation and request of my wife, I "acquired" some new netting material. I had to to really stretch it to get the grid pattern to expand enough, but in the end, I think it worked out. Just need to paint like the others,
Plan to get the groundwork started in the next few days. Countdown to AMPS has started, so the pressure is on....
Cheers!
