Armor/AFV: Modern - USA
Pascal's Cougar 6X6 Meng 1/35
pascalbausset
Moselle, France
KitMaker: 1,416 posts
Armorama: 1,379 posts
Posted: Tuesday, January 20, 2015 - 10:24 AM UTC
As said i have received the last Meng's kit.
The Cougar comes in an usual big box, with lots of beautifuly mouldes sprues.
Two type of truck are possible. They name them : Cougar 6X6 and Cougar 6X6 HEV
I took sprues pictures later this morning.
In the box we can find :
-15 yellow plastic sprues +main upper body
-6 clear sprues; As for the D9 there is clear windows and green tinted one.
-8 vynil tires without moulding line
-a little PE sheet and decals for the 2 versions.
The kit come with lots of antenna, and I can't wait to begin it!!!!!!!!
Looking on the sprues I think that Meng will deliver soon a 4X4 version, but it is just my opinion don't ear rumour about this
mmarchioli
KitMaker: 173 posts
Armorama: 168 posts
Posted: Tuesday, January 20, 2015 - 10:26 AM UTC
Can't wait for this one!
Hisham
Al Qahirah, Egypt / لعربية
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Tuesday, January 20, 2015 - 11:26 AM UTC
How about a pic of the instructions showing how the suspension goes together.. to compare to Panda's suspension
Hisham
pascalbausset
Moselle, France
Posted: Tuesday, January 20, 2015 - 02:52 PM UTC
Some view from what is in the box :
The seats belts :
Comparison between the Panda and Meng upper hull. I'am surprised with the engine hoods length. Any informations about this ?
Vodnik
Warszawa, Poland
KitMaker: 4,342 posts
Armorama: 3,938 posts
Posted: Tuesday, January 20, 2015 - 03:05 PM UTC
Are both hulls the same width? It's impossible to tell from this photo.
mvaiano
Sao Paulo, Brazil
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Tuesday, January 20, 2015 - 03:09 PM UTC
Hi!
Thanks a lot Pascal! I'll order mine today.
Cheers!
Marco
barny
KitMaker: 273 posts
Armorama: 272 posts
Posted: Tuesday, January 20, 2015 - 03:11 PM UTC
Def on the toget list.
Terry
pascalbausset
Moselle, France
Posted: Tuesday, January 20, 2015 - 03:22 PM UTC
The Panda hull is 3mm narrower than the Meng's one.
Vodnik
Warszawa, Poland
Posted: Tuesday, January 20, 2015 - 03:36 PM UTC
So it looks like there is a scale problem - MENG kit is just generally larger. The question is which one is more accurate...
The width of both kits should be 77.4mm (2710mm in 1:1) at rear side marker lights. I will try to verify it on parts of my Panda Cougar this evening.
Vodnik
Warszawa, Poland
Posted: Tuesday, January 20, 2015 - 03:55 PM UTC
Pascal,
What is the length of the hood in the Meng kit?
My quick measurements and calculations suggest that it should be between 48 - 49 mm to be reasonably accurate. Of course it should be identical in both kits...
Hercules1983
Shanghai, China / 简体
KitMaker: 43 posts
Armorama: 43 posts
Posted: Tuesday, January 20, 2015 - 05:16 PM UTC
Meng's engine hood length is 54.5mm...
Vodnik
Warszawa, Poland
Posted: Tuesday, January 20, 2015 - 05:23 PM UTC
Ouch... It doesn't sound good... I hope Meng didn't make a mistake of assuming the vehicle length in specifications does not include the boarding steps at the rear... In fact it does. Such mistake could result in an overscale model. But I hope I'm wrong... I really do...
Hercules1983
KitMaker: 43 posts
Armorama: 43 posts
Posted: Tuesday, January 20, 2015 - 06:13 PM UTC
Panda's hood is around 50.5mm.And I heard that Panda has measured the actual vehicle, maybe their cougar is more accurate?
Vodnik
Warszawa, Poland
Posted: Tuesday, January 20, 2015 - 06:17 PM UTC
50.5mm is certainly closer to my rough estimates. I think the verification of the kit width could confirm whether the Panda kit is closer to correct dimensions.
mvaiano
Sao Paulo, Brazil
Posted: Tuesday, January 20, 2015 - 07:09 PM UTC
Just a question:
Why 8 tires?
Cheers!
Marco
Hisham
Posted: Tuesday, January 20, 2015 - 07:12 PM UTC
Two spare tires hanging on the sides
Hisham
sauceman
KitMaker: 2,672 posts
Armorama: 2,475 posts
Posted: Tuesday, January 20, 2015 - 07:46 PM UTC
Looks like a better start for my JERRV!
cheers
Youngun
KitMaker: 587 posts
Armorama: 550 posts
Posted: Tuesday, January 20, 2015 - 07:54 PM UTC
Ordered mine from Hobby Easy, sprang for the Express shipping so hopefully it's here by the end of next week maybe even this week.
mvaiano
Sao Paulo, Brazil
Posted: Tuesday, January 20, 2015 - 08:17 PM UTC
Hisham
Thanks! It can has spare tires...
Cheers!
Marco
sauceman
Posted: Tuesday, January 20, 2015 - 08:38 PM UTC
Here's some dimensions for the JERRV, should be the same I would think.
cheers
henkp
Overijssel, Netherlands
KitMaker: 1,080 posts
Armorama: 1,064 posts
Posted: Tuesday, January 20, 2015 - 09:06 PM UTC
all whe need is a gyrocam
henk
Vodnik
Warszawa, Poland
Posted: Tuesday, January 20, 2015 - 09:22 PM UTC
I just measured the Panda kit width. It's 73.2mm at rear side marker lights... this means it's 4.2mm too narrow... Doh... So Panda kit is certainly not accurate in width - the Meng might be closer if it's main hull shell is 3mm wider (the question remains whether the entire vehicle, after attaching the fenders, will also be appropriately wider than the Panda kit...).
I'll try to assemble a few more parts to measure it's length now.
EDIT: Easier said than done... Instructions in my Panda kit are missing a few pages... Arghhh...
18Bravo
KitMaker: 7,219 posts
Armorama: 6,097 posts
Posted: Tuesday, January 20, 2015 - 09:30 PM UTC
Hisham
And as you'll see from my photos armored plate was often substituted for the tires as they were prone to catching fire.
pascalbausset
Moselle, France
Posted: Tuesday, January 20, 2015 - 09:52 PM UTC
I can send youa copy from the Panda's instruction sheet
Hisham
Posted: Tuesday, January 20, 2015 - 09:55 PM UTC
Here you go, Pawel... on Hobby Search
Hisham
