Thanks guys for the warm greetings and the encouragements. The knees are getting better every day. I hope to be back at it in the very near future.
Keep up all the great modeling work out there!
Mike
White 666 Semi-Tractor
Posted: Monday, December 14, 2015 - 10:28 AM UTC
Posted: Monday, December 14, 2015 - 10:55 AM UTC
Mike,
How many parts and piece from the 666 be used on the Mack NO7? Wondering because the rear springs and axles look similar to those used on the NO7, wheels look like those used on the NO also. In the planning stages for building the Mack NO
DJ
Not much from the White 666 works for the Mack NO6. Mack came up with a much heavier construction and of course they employed their exclusive "camel back" rear leaf springs that are like nothing else in the industry.
The starting point for my Mack NO6 was the Tamiya Dragon Wagon tractor. First of all the tires are the correct size for the Mack. Also the wheel rims are the correct diameter though you need to narrow the rims by about the width of a dremel cut off abrasive blade. The wheel centers on the Dragon Wagon are all wrong for the Mack. However if you order the back dating wheel set from Scale-Link designed for the AFV Club eight inch gun (get the set that comes WITHOUT the M1 limber) you will receive separate wheel centers that are very usable for the Mack.
Finally the Dragon Wagon kit also provides front axle/differential, rear differentials, parts of the transfer case, drive shafts, frame parts, front leaf springs AND the beautiful Gar-Wood winch you will need for the Mack. (The DW winch is a newer version and will need to be back dated slightly.)
A more or less step by step "how to" on how I built my Mack NO can be found at:
http://armorama.com/forums/196219&ord=&page=1
Posted: Monday, December 14, 2015 - 09:44 PM UTC
P.S. The Scale-Link after market wheel set will also give you the air brake actuator cylenders you will need for the Mack.
Again, be sure to order the back dating wheel set that comes WITHOUT the M1 limber as those wheel castings offer separate wheel drum centers. The other back dating wheel set, also offered by Scale-Link, is from an entirely different set of masters that cast the tire and the wheel drum as all one piece.
Posted: Tuesday, December 15, 2015 - 12:51 AM UTC
Posted: Thursday, December 17, 2015 - 01:30 PM UTC
Better get back to the White tractor:
http://s1061.photobucket.com/user/165thspc/slideshow/White%20666%20Semi-Tractor
Posted: Friday, April 08, 2016 - 04:28 AM UTC
Thought I would add a splash of color to my White Semi-Tractor; Stole this idea from Jacob Hederstierna-Johnse and his Diamond T Wrecker. Some brightly colored oil cans from Plus Models.
So far I have won 2 Second Place trophies in the "Scratch Built and Conversions" catagory with the tractor and the 20 ton trailer. Heading for the Dayton Regional tomorrow. I have hopes to up my game and catch a first place this time.
Check out Jacob's wrecker at:
https://armorama.kitmaker.net/forums/245403&page=1
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Friday, April 08, 2016 - 07:25 AM UTC
Wow!
What kind of job do the first place?......
Good Luck and again, great job!
Regards
Alvaro
Regards
Alvaro
Posted: Sunday, April 10, 2016 - 02:36 AM UTC
Posted: Sunday, April 10, 2016 - 11:32 PM UTC
Frenchy
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Monday, April 11, 2016 - 01:37 AM UTC
Hi Michael
I've recently came across some Korea War pics that may interest you. These trucks belonged to the 388th Engineer Pipeline Company, US 8th Army.
(from this page : http://blog.joins.com/media/folderListSlide.asp?uid=fabiano&folder=33&list_id=13782778&page=1 )
Another one here
H.P.
Another one here
H.P.
Posted: Monday, April 11, 2016 - 06:03 PM UTC
Thanks Frenchy. I especially like the shots of the Triple 6 semi-tractor with the winch mounted up front!
Posted: Monday, April 11, 2016 - 06:24 PM UTC
Wow!
Regards
Alvaro
Thanks Alvaro but as they say "on any given Saturday - you can win big or you can go home licking your wounds".
Only took home two third place awards at the Dayton Regional! Met some tough competition but also some tough judging.
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Monday, April 11, 2016 - 06:39 PM UTC
Well, next time for sure!
Regards Alvaro
Regards Alvaro
Posted: Monday, April 18, 2016 - 07:36 PM UTC
Anyone have any thoughts on how a 1940's era airbrake hose hanging frame would have been arranged behind the cab of a semi-tractor?
My thoughts now are to make a three piece frame out of angle iron (Evergreen shapes). Then two pipes coming up to end either in air valves or gladhands. Then the air hoses attached to these.
My only references to-date:
Air lines mounted behind cab on a frame but no winch in this case.
Here the air lines appear to be going forward towards the cab but again this vehicle had a front mounted winch.
Looks here like the airlines are attached under the rear of the tractor frame which is how the Dragon Wagon did it in order that the air lines not interfere with the operation of the double winch.
Posted: Friday, May 20, 2016 - 12:48 AM UTC
Posted: Saturday, May 21, 2016 - 10:16 PM UTC
Posted: Saturday, May 21, 2016 - 10:21 PM UTC
Posted: Sunday, May 22, 2016 - 01:52 AM UTC
Posted: Sunday, May 22, 2016 - 01:55 AM UTC
However, I guess it is one of those "On any given Saturday" type of things:
Because at the Louisville IPMS regional yesterday these models took a First Place in the Conversions class AND also took a unanimous "Best Armor" award as voted by all the Judges! Thanks guys!
I admit, this time I spiced up the tractor just slightly by adding rear view mirrors and the trailer by adding air brake lines. I also dressed up that center deck with all the tools, etc. But personally I think what really did it for me was that I posed the rig on that big mirror. I no longer had to reply on photographs to show the judges the detail that had been added underneath the tractor and trailer. We may never know . . .
The President of the Chapter was announcing the winners and he said; " I am a car modeling guy so I am proud to say that the Best Armor award has been won by a truck!"
Bigred69
KitMaker: 290 posts
Armorama: 249 posts
Posted: Sunday, May 22, 2016 - 03:04 AM UTC
Michael, Congratulations on your First prize. What an awesome looking model combination. I will use your info when I build my kit. Thanks.
Posted: Monday, May 23, 2016 - 06:45 PM UTC
Thank you Sir. This is only the second time in my life I have won a Best Armor award. The funny thing is both times I won it with a truck!
Posted: Thursday, May 26, 2016 - 10:00 PM UTC
Hey Mike - congratulations on your win! Great build. I always enjoy watching your truck builds - remarkable stuff! Like the leaf spring pack above - nice work!
Nick
Nick
Posted: Saturday, May 28, 2016 - 06:58 PM UTC
Thanks Stick and Ron.
There were plenty of top quality armor models in this competition. No on was more surprised than I.
Bigred69
KitMaker: 290 posts
Armorama: 249 posts
Posted: Saturday, May 28, 2016 - 10:22 PM UTC
Michael, the surprise wins are the best, because you Built something that they have yet seen. Like I said before, Congratulations on the win. Keep up the good work.
Ronnie
Ronnie
Frenchy
Posted: Saturday, May 28, 2016 - 10:42 PM UTC
Well done Mike !
H.P.
