New Mexico, United States
KitMaker: 681 posts
Armorama: 603 posts
Posted: Wednesday, September 28, 2016 - 09:03 AM UTC
On the Bench
MiniArt Grant Mk I with Interior
IBG Marmon-Herrington MKII
SgtRam
Contributing Writer
#197
KitMaker: 3,971 posts
Armorama: 2,859 posts
Posted: Sunday, October 02, 2016 - 04:26 AM UTC
Starting on cab and bed painting.
KitMaker: 3,694 posts
Armorama: 2,693 posts
Posted: Sunday, October 02, 2016 - 04:38 AM UTC
Nice progress, guys.
Any fit problems on the Matador?
I am hoping to make progress on the Wiesel tonight. I managed to cut out the teeth from the PE fret. Tried a new blade in my X-Acto but that didn't seem to have any effect. I ended up using a wire cutter.
I also tried painting the wheels with NATO Green but it does look too dark. I will try some RLM80 Olive Green (as per instructions).
I still need to cut out those supports on the suspension arms, although they would be hidden behind the wheels.
KitMaker: 681 posts
Armorama: 603 posts
Posted: Sunday, October 02, 2016 - 08:17 AM UTC
Very slight progress on the Stuart V. Making the barrel for the .30 cal was the part that took the longest.
PH
On the Bench
SgtRam
Contributing Writer
#197
Posted: Sunday, October 02, 2016 - 03:48 PM UTC
@Gary - so far, I have found no fit issues. I have found a few part numbers issues in the instructions, but that is it.
KitMaker: 73 posts
Armorama: 58 posts
Posted: Sunday, October 02, 2016 - 03:52 PM UTC
Here is my entry
I `ll post some progress shots along the way
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Wednesday, October 05, 2016 - 05:03 AM UTC
Hi fellas. There is some nice work going on in here.
This is my campaign entry.
Cheers!
#454
Georgia, United States
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Wednesday, October 05, 2016 - 05:21 AM UTC
Looks to be a beast, Dustin! Looking forward to your build!
"I can make armored cars, safe and unassailable...and behind these our infantry will be able to follow quite unharmed and without any opposition."
-Leonardo da Vinci, 1487
Posted: Wednesday, October 05, 2016 - 06:22 AM UTC
Posted: Wednesday, October 05, 2016 - 03:50 PM UTC
Good to see Strykers coming on board! When will the first M60s show up?
Tennessee, United States
KitMaker: 1,290 posts
Armorama: 658 posts
Posted: Thursday, October 06, 2016 - 08:08 PM UTC
Paul,
Did you make a jig or use a piece of plastic strip to form the tie downs?
Jeff
KitMaker: 681 posts
Armorama: 603 posts
Posted: Thursday, October 06, 2016 - 09:11 PM UTC
Jeff,
I put one end of the tie down under one of the fingers on one of my PE
bending tool and bent that side up. Then I created a form from copper sheet that was cut to the right width. The strips were stacked to the right height to act as a form and soldered together. I butted that form up against the piece clamped in the PE bender and used a straight edge to force the bends over the form. Since my examples weren't etched symmetrically I need tweezers to tweek everything into alignment.
I tried styrene strip as the form first, but it deformed very easily and produced sloppier bends.
I'm away from my bench, but if you need some pics I can make them this evening. Just let me know.
Hope this helps
PH
On the Bench
Armorama: 658 posts
Posted: Friday, October 07, 2016 - 02:46 AM UTC
Paul,
I would appreciate some photos. Thanks.
Jeff
I discovered that I do not have an AFV kit in my ready-rank (closet), but they are all in temporary storage. Once the temperature drops over the weekend I can go recover some of the kits. I had moved out most models to make room for contractors to build out 2nd floor of my house. Delays in finance department has slowed down the work. Hope to get something on this site in next couple weeks.
Komarom-Esztergom, Hungary
KitMaker: 10 posts
Armorama: 9 posts
Posted: Friday, October 07, 2016 - 03:24 AM UTC
Greetings!
This is my entry.
#454
Posted: Friday, October 07, 2016 - 03:35 AM UTC
Greetings!
This is my entry.
You don't see that one often, looking forward to your build, Nemeth!
KitMaker: 681 posts
Armorama: 603 posts
Posted: Friday, October 07, 2016 - 04:01 AM UTC
Paul,
Jeff
Jeff,
Misplaced original form so here is one I cobbled together from brass PE frets.
First bend
Place form against part...
Bend with straight edge...
Finished part...
Hope this helps!
PH
On the Bench
KitMaker: 681 posts
Armorama: 603 posts
Posted: Friday, October 07, 2016 - 10:26 AM UTC
I actually got a couple of hours at the workbench! Seems like forever since I worked on the Stuart even though it's only been 3-4 days. I spent the time
soldering together some of the turret exterior fittings.
PH
On the Bench
Bayern, Germany
KitMaker: 1,615 posts
Armorama: 1,500 posts
Posted: Friday, October 07, 2016 - 12:42 PM UTC
Paul, your PE work amazes me again and again!
(is that the smiley for salute or coockoo?
Building logs: http://armored76.wordpress.com/
Finished projects: http://armored76.wordpress.com/portfolio/
Western Australia, Australia
KitMaker: 247 posts
Armorama: 126 posts
Posted: Friday, October 07, 2016 - 03:45 PM UTC
#454
Posted: Friday, October 07, 2016 - 06:27 PM UTC
That helps me, too! What a time saver! Thanks!
Posted: Friday, October 07, 2016 - 08:29 PM UTC
And now we add a pair of Centurions to the campaign. Welcome guys.
LinusB, don't forget to enlist in the campaign!
AFV Club Campaign New Mexico, United States
KitMaker: 681 posts
Armorama: 603 posts
Posted: Friday, October 07, 2016 - 08:36 PM UTC
@ Cristian. Cuckoo, is probably the most accurate, but that has nothing to do with the PE... Thanks for the multi-use emoji and the nice comment
@ Clayton, I really glad you found the info useful!
On the Bench
Armorama: 658 posts
Posted: Saturday, October 08, 2016 - 01:43 AM UTC
Paul,
Excellent tutorial. Actually much simpler than what I was thinking. Thanks.
Jeff
KitMaker: 681 posts
Armorama: 603 posts
Posted: Saturday, October 08, 2016 - 03:39 AM UTC
Jeff,
Glad you found it useful. I do some things that are needlessly complicated, but I try to limit the insanity whenever I can.
PH
On the Bench
SgtRam
Contributing Writer
#197
Posted: Sunday, October 09, 2016 - 08:38 PM UTC
A little more work done on the Matador with the cab interior done.
