mmeier,
wierdy,
I'll check out the books, thank you.
Armor/AFV: What If?
M4E13 Panther F
m4sherman
KitMaker: 1,866 posts
Armorama: 1,808 posts
Posted: Saturday, July 23, 2016 - 09:27 PM UTC
m4sherman
Posted: Sunday, July 24, 2016 - 08:27 AM UTC
m4sherman
Posted: Sunday, July 24, 2016 - 09:02 AM UTC
Some thoughts on the M4E13P 75mm KwK 42 L/70, the more Sherman version I have planned.
As pointed out to get a working tank, in any quantity, combat ready in the 18 months I determined we have to work with, means I need to scale back my modifications.
The GAA engine can be part of the upgrades. There was a plan to drop all the other M4 engines for the big V8 so what is needed is already known and conversion kits could be made available. The base lower hull is the same for all the early M4's, except the longer 'A4, so all that is needed is to change to the 'A3 type. The upper hull can be easily changed by spacing out the rear plate.
I think priority to upgrade to the HVSS suspension would be given to the tanks with the 76mm turrets, as those tanks could be re-armed with the US 90mm gun. However, I think that HVSS suspension is something that would be easily manufactured in the Ruhr, so I will use it on my tank, with a few minor tweaks to show it is not the "US" made stuff. The tracks will be the US T-66, and also could be made locally.
I will add armor to bring the tank hull up to 'E2 specs, but less elaborate and more M4'ish.
After a lot of consideration I plan on using the F type gun mantlet on the new build. It looks good, can be mounted with few modifications to the turret, and does not block the drivers hatch unless the turret is pointed that way.
If anyone has some suggestions, let me know. The build will start in a couple days.
m4sherman
Posted: Tuesday, July 26, 2016 - 02:53 AM UTC
Just about got this one finished. I had to move the tools around, add the tie down loops, from Arms Corps Models, add the straps and buckles. I ordered a set of pe chains that are still on the way. As soon as I took the pictures it dawned on me I haven't got the fenders figured out, and a couple other nik naks need to be added.
None the less the build step is 99% done, and I'm happy with it. Now, what sort of paint job should it get?
saurkrautwerfer
KitMaker: 44 posts
Armorama: 44 posts
Posted: Tuesday, July 26, 2016 - 05:29 AM UTC
Maybe keep it OD or the OD with improvised black stripes, but with some dunklegelb road wheels or something.
m4sherman
Posted: Tuesday, July 26, 2016 - 06:23 AM UTC
The camo on the M4A1 with the Pershing turret (page 2)is one option. Or the brown over green seen in Normandy. Another option is to use the German green. I want to keep the OD a lighter green, but a shade darker than the JagdSherman on page 2.
Unreality
KitMaker: 172 posts
Armorama: 145 posts
Posted: Tuesday, July 26, 2016 - 06:58 AM UTC
I am really loving this "Schermpanther". Great idea and scratch-building. Now the big question....will it have a bucket?
Homer0331
KitMaker: 148 posts
Armorama: 148 posts
Posted: Tuesday, July 26, 2016 - 08:33 AM UTC
I'm loving this!
I want to combine the Jumbo's hull, HVSS and a Pershing turret for my "47 build.
Look at Tamiya XF-73 for a lighter green shade.
m4sherman
Posted: Tuesday, July 26, 2016 - 09:40 AM UTC
I looked, and I don't have a bucket...
Maybe I can get a loaner!
m4sherman
Posted: Tuesday, July 26, 2016 - 09:45 AM UTC
I'm loving this!
Sounds like a good '47 project.
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Tuesday, July 26, 2016 - 02:45 PM UTC
Premise:
The atom bomb test failed, and Stalinist traitors inside the Manhattan Project informed Stalin he had nothing to worry about. He decided to attack into western Germany on March 1st, 1947. Goal, destruction of the Western Army, and then the conquest of western Europe. The bulk of the Stalinist armored forces will be the T-34 85, supported by the IS series heavy tanks, with the new T-44 tanks available in limited numbers.
Western Army forces are the US M4 75mm, 76mm and 105mm tanks. The M26 and M26E4 Pershing series, and the new British Centurion
Challenge:
What could be done to turn an early M4 series tank into a T34 killing machine before spring 1947?
The Western Army has 18 months, all the spare resources in the US, all the resources of the Ruhr industrial complex, access to all the guns, munitions and spare parts left over from the US and German war efforts.
About 26,000 M4, M4A1, M4A2 and M4A4 small drivers hatch tanks were built. Suppose that around 1/3, or 8,600 are available:
M4 2,200
M4A1 2,000
M4A2 2,000
M4A4 2,400
Here is what I came up with. 90% completed, a What the Hey! What If. I was going to wait until I had the turret wrapped up, but I needed to get some parts, so opted to post the nearly finished model.
To be sure, this project IS a novel idea-
Once again, not to steal your thunder, and I'm just throwing some observations regarding the "1947"-scenario about, but:
a) Logically, by 1947, wouldn't it be possible that the US Army and the US War Production Board would have put priority on M26 Pershing production, rather than than re-design/re-fit or re-manufacture M4A3E8 (HVSS) Tanks with T26/M26 Turrets and German Panther-type Suspensions? Patton would have had an apoplectic FIT!!!
Cannibalizing Panther Suspensions is not out of the realm of possibility, but wouldn't that be VERY time consuming and an impractical mis-use of available M4s, M4A1s, M4A2s, and M4A4s, when every single one of these would have been required to combat the "Eastern Forces"? Wouldn't it make more sense to forego the aforementioned M4-series Mediums in favor of M4A3E8 (HVSS) Tanks..?
I suppose that manufacturing Panther Suspensions in the US MIGHT have been possible, but there again, that would have required opening up an entirely NEW Production Line, if not a new Manufacturing Plant!
A more viable solution in countering the Soviet Tank forces, IMO, could have been to manufacture M26s (Standard 90mm and/or 90mm T15E1 Gun), T29/T29E3s (105mm Gun), T30/T30 (155mm Gun), or the T32E1 (with the new 58-degree Hull and armed with the T15E1 90mm Gun)... This would make more sense to me...
b) It's a well known fact that M4A3E8 (HVSS) Shermans serving in Korea (1949-1953) were defeating Soviet-made T-34/85s on pretty much a regular basis, so doesn't it stand to reason that "Easy Eights" could have dispatched T-34/85s in the same fashion in 1947..?
Personally speaking, I don't dwell on "what if" scenarios; it's pretty well established that the United States, by early 1944, was not only a military, but also an industrial Superpower, with which the Soviets would entirely have had their hands full...
"LEND-LEASE" would have been very abruptly terminated where the Soviet Union was concerned...
Also, let's not forget that the majority of German engineers and scientists, (Wernher Von Braun, et al) had given themselves up to Allied Forces, rather than fall into Soviet hands. The Allies' taking advantage of the wealth of advanced German weaponry and knowledge against the "Eastern Forces" are a moot point, I think...
BTW- The Atomic Bomb tests WERE SUCCESSFUL, Hiroshima and Nagasaki notwithstanding, and that WAS in 1945, since we're discussing "1947", here. It's quite possible that Stalin might have directed his forces to keep going past the Elbe, despite the US having become the first "Nuclear Power" in the world...
So guys, chew on THAT if you will, but ENJOY Randall's project, by all means!
Again, this is a GREAT PROJECT!!!
Cantstopbuyingkits
KitMaker: 2,099 posts
Armorama: 1,920 posts
Posted: Tuesday, July 26, 2016 - 02:54 PM UTC
I'm loving this too, was planning on doing a similar project by the British on their obselete Sherman. It would have a Centurion style suspension and Metoer engine added to the M4A4 chassis.
M4A1Sherman
Posted: Tuesday, July 26, 2016 - 03:07 PM UTC
Weren't early Centurion Is (A41s) already being used in troop trials by May, 1945? Since we're looking at a "1947"-type of scenario, I should think that Great Britain would have had several different Marks of the Centurion in full-scale production by 1947...
Also, let's not forget that the British Army already had Comets (A34s) serving in Europe by January, 1945...
m4sherman
Posted: Tuesday, July 26, 2016 - 05:59 PM UTC
Again, this is a GREAT PROJECT!!!![]()
I think I answered most of this in previous posts. For the M-26 there was about 2,000 produced. If you increase production you still would not have enough combat ready tanks by March 1947.
I went over the top on this one, and the next will be more Sherman.
m4sherman
Posted: Tuesday, July 26, 2016 - 06:04 PM UTC
I looked at the Centurion boogies early on, but it was the sloped lower hull that stopped me. A Centurion would be a great counter to the T-34's, and I think would be upgraded a lot faster with a shooting war coming.
Cantstopbuyingkits
Posted: Tuesday, July 26, 2016 - 07:30 PM UTC
Quoted TextI'm loving this too, was planning on doing a similar project by the British on their obselete Sherman. It would have a Centurion style suspension and Metoer engine added to the M4A4 chassis.
I know the British would have had a reasonable amnount of new advanced tank designs by 1947, I was more thinking of a way to prolong the usefulness of the 8,000+ Shermans the army still had, which would have been obselete day the former without upgrades.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Tuesday, July 26, 2016 - 08:06 PM UTC
The suspension is very do able since it's bogie system like the VVSS and HVSS...again the Engine would be the big problem. But the Centurion Suspension could be done minimum with an adapter plate.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Tuesday, July 26, 2016 - 08:08 PM UTC
Would they have enough to restock their forces? The Comets were in one Division the 11th...The 7th had Cromwells, and the Guards had Shermans, but was demobed as an Armoured Division and became an Infantry Division, with the third Brigade being the 6th Guards Army Tank Brigade also demobbed as Armour.
m4sherman
Posted: Tuesday, July 26, 2016 - 09:55 PM UTC
I absorbed about half of the British M4's into my Western Army figures. I guessed the British Army would try to standardize with the Centurions, but would want to keep as many Fireflys as possible to back up the Cromwell tank units. Keep in mind I am doing a lot of guessing here.
m4sherman
Posted: Tuesday, July 26, 2016 - 10:05 PM UTC
I agree, but did not look closer. Another factor is the length of the hull. The Centurions have a long hull, would three boogies fit on the M4A4 hull?
Now I did check out one suspension on the M4, the Porche boogies from the Elefant. Those would fit the standard M4 hull.
But, I went Panther on the model.
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Tuesday, July 26, 2016 - 10:33 PM UTC
I just remembered this fact which might help. The US Army never had enough M26's for their requirements. They had a substitute standard in the M4A3 76W HVSS, which they also didn't have enough of to even back fill to their requirements. So they started a program where they would strip all Non M4A3 76W HVSS of parts and use them to rebuild tanks to that standard. Alot of 105 HVSS and 75W HVSS got turrets off of M4A1 76W's and M4A2 76W's that were in depots. Also there were alot of M4A3 76W VVSS that got HVSS suspensions.
Also to make up for shortages they had the M4A1E6 and M4A3E4 programs which was fitting the 76mm into the 75mm turret. They were done by BMY and Tokoyo Arsenal. The M4A1E6 were on small hatched hulls, and the M4A3E4 was on Large Hatch Hulls, and all had VVSS.
M4A1Sherman
Posted: Tuesday, July 26, 2016 - 11:49 PM UTC
There were only about 2,000 M26-types produced because, in the "real" world, the US Army was already a step ahead by war's end, i.e, the M46 was already on the drawing boards. That, and the fact that no one anticipated WWII lasting much longer, given the successful Atomic Bomb Missions. It's ALSO quite possible that other US Heavy Tanks, i.e the T26E4/T26E5 (with the T15E2 90mm Gun- T25E5 had heavier armor), T29/T29E3 (105mm Gun, NO relation to the M1/M2 105mm Howitzer), the T30/T30E1 (T3 155mm Gun) T32 and the T34 (T53 120mm Gun) which actually WAS built in 1947...
Had the US Armor Board, the American Ground Forces establishment, and US Ordnance NOT have been so pig-headed regarding the M26, and had the M26-production been given top-priority, there conceivably COULD have been a lot more than 2,000 M26s on hand by "1947". Remember, the "late-1945", "1946" and "1947"-scenarios never happened. All of this "1947"-stuff is all conjectural anyway, so who knows what American industry might have accomplished if the "1947"-scenario actually DID happen...
As I said before, this project of yours is a really novel idea, and it has really whipped up the enthusiasm for other like-minded projects! I personally don't think that you went "over the top" with this project- The fact that you are re-thinking the whole thing and coming up with some other things that are a bit more "in line" with US AFV conceptual thinking has me pretty interested in what you WILL come up with next!
DG0542
KitMaker: 125 posts
Armorama: 125 posts
Posted: Wednesday, July 27, 2016 - 12:26 AM UTC
The M26 failed the Armored Board Test, and Army Ground Forces acted upon the Armored Board recommendation. The GAF Engine was not what was needed and that was why they started the program that eventually became the M46, because the GAF Engine was too under powered and to improve the coolant system of the M26. It was Ordnance that pushed the deployment of the T26E3.
http://worldoftanks.com/en/news/pc-browser/21/The_Chieftains_Hatch_Pershing_1/
That's the first of a series of articles on the Pershing, and stats that the mechanical reliability is a major reason for its rejection...and he uses source documents.
Posted: Wednesday, July 27, 2016 - 12:35 AM UTC
Great build! Seems to be more work to convert to this model than make a new tank. However, I love the alternative history and the hybrid look of the tank.
Notice for anyone interested there is a Sci-Fi and alternative history Campaign starting in September for just this kind of build. It is over at the model geek part of the network. Click my banner to see more.
Cantstopbuyingkits
Posted: Wednesday, July 27, 2016 - 02:23 AM UTC
Quoted TextQuoted TextI'm loving this too, was planning on doing a similar project by the British on their obselete Sherman. It would have a Centurion style suspension and Metoer engine added to the M4A4 chassis.
Now I did check out one suspension on the M4, the Porche boogies from the Elefant. Those would fit the standard M4 hull.![]()
But, I went Panther on the model.![]()
I noticed that too [Cent is 5.3 foot longer than the M4A4]. My idea was to use only 2 bogies, though I am, not sure that many could hold the bigger engine and extra armour though.
