Campaigns: Active Campaigns
Hosted by Richard S.
Crusader to Gazala Campaign
Removed by original poster on 11/30/17 - 04:30:18 (GMT).
Removed by original poster on 11/30/17 - 04:37:12 (GMT).
Removed by original poster on 11/30/17 - 04:38:06 (GMT).
Removed by original poster on 11/30/17 - 04:41:06 (GMT).
Removed by original poster on 11/30/17 - 04:54:47 (GMT).
Posted: Wednesday, November 29, 2017 - 12:14 PM UTC
Welcome Mr. Clark!
A pink Stuart would definitely add some variation to the color schemes. But errr... I don't think I could make myself paint anything pink unless it was for my granddaughter.
Gaz
Gaz
petbat
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Wednesday, November 29, 2017 - 01:07 PM UTC
Welcome Mr. Clark!
Gaz
It is a bit on an 'In Joke'. Kelly and I have done a few Group Builds together and painting a model pink is an on going discussion...
RobinNilsson
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Wednesday, November 29, 2017 - 01:10 PM UTC
Quoted TextWelcome Mr. Clark!
Gaz
I built a Pink Panther once .....
petbat
Posted: Wednesday, November 29, 2017 - 01:16 PM UTC
Apparently you are not the only one...
spacewolfdad
KitMaker: 642 posts
Armorama: 593 posts
Posted: Wednesday, November 29, 2017 - 01:43 PM UTC
Nice work Paul. An interesting solution... I bet you were so careful in cleaning out the wheels from those tracks.
Only two slight cuts to the fingers, the plasters then acted as 'buffers' against further cuts
All the best,
Mrclark7
KitMaker: 503 posts
Armorama: 477 posts
Posted: Thursday, November 30, 2017 - 05:25 AM UTC
Welcome Mr. Clark!
Gaz
Thanks Gary, no pink, but it will be done soon on another model. Its a way to remember a memory from the past. Will explain when I finally finish it.
JohnDoe4th
KitMaker: 142 posts
Armorama: 137 posts
Posted: Thursday, November 30, 2017 - 09:58 AM UTC
Yeah, My fault for all the Removed by.... I just couldn't remember how to attached images through FB. Created a Imgur acct and hopefully it works
YES it work!! Picture for discussion only
Okay..
Build is coming along better now that the warp issue is fixed. Took some time, patience, C-Clamps and CA to fix. I think I did a good job for being the first warped issue so far. Have read Dragon is famous for warp pieces.
Sanded all the wheels, tracks and some other pieces. Assembled the tracks but haven't added any primer. All this work was done before I joined this campaign.
I had a few hours to work on the Greif this past Holiday weekend. As you can see in the pic below that there are gaps and fitting issues that need to be fixed.
After mixing Squadron green putty with Tamiya extra thin cement too thin-out the putty. I used an old brush to fill-in the gaps. Then I added some extra putty to the already mixed putty for some thickness and finished off the rest.
After a day or two of drying. It was time to bring out the Tylenol, sand paper and a flat block for some repairs.
I also had some painting time over the weekend. Still need to finish has you can see in the pics. I used Tamiya fine surface primer rattle can. Then I sprayed the track wheels, front tire hubs and the upper interior of the Greif RAL7021 Dunkelgrau (AK704) by AK Interactive for the base coat.
Ill be using AK interactive Rubber/Tires (AK720) paint for the tires and the road wheels rubber.
For the tools, ill be painting them with AK Interactive Wood Base (AK779), Wood Grain (AK781) and Gun Metal (AK798).
Greifs whole Interior been premiered and waiting for the base coat of RAL7021. Im going to use the hairspray technic for the first time. If I just sprayed the base coat (RAL7021) over the primer (Tamiya can) then start chipping, the primer would show and it wouldn't look right (imo). My questioned is, what primer did the German used before they sprayed the whole 250 RAL7021? I notice in the hairspray chipping video, that red primer was used. Was it used also on the 250s?
All comments are welcome.
Thanks
JohnA
Okay..
Thanks
JohnA
petbat
Posted: Thursday, November 30, 2017 - 10:50 AM UTC
Nice start John. Just watch those Idler adjusting 'rods'. I have learned to leave that part of the assembly til after I have wrestled the rest. The number of times I broke them off..... and lost them...
Posted: Thursday, November 30, 2017 - 11:24 AM UTC
John,
You're off to a great start! I haven't built a half-track in a long time, so I'll be watching with interest.
Gaz
Gaz
JohnDoe4th
KitMaker: 142 posts
Armorama: 137 posts
Posted: Thursday, November 30, 2017 - 12:10 PM UTC
HA.......
Peter and Gary already posted a comment about my build before I hit the edit reply tab.
Thank you both for the comments!! This build is going together nicely after the first step issues. Hopefully ill have some time over the weekend for some painting and detailing.
JohnA
JohnA
Posted: Thursday, November 30, 2017 - 12:55 PM UTC
HA.......
JohnA
I'm, what part does the Tylenol play in sanding the putty? Or does the process just give you a headache?
Gaz
petbat
Posted: Thursday, November 30, 2017 - 12:56 PM UTC
Before you edit again....
The Germans used a dark red oxide primer for most vehicles and the SDKFZ 250 was one of them, but be wary of using that as your chipping base. It will likely appear too red and overdone.
Chaman911
KitMaker: 319 posts
Armorama: 308 posts
Posted: Thursday, November 30, 2017 - 10:07 PM UTC
Hi everyone. Thought I would share another video on chipping as it seems to be a hot topic. This is another guy who has a lot of good videos on You Tube. I especially like that he doesn’t get too complicated with his techniques. https://m.youtube.com/watch?t=778s&v=xsceaIRCFyU
Hope everyone’s build is going well.
JohnDoe4th
KitMaker: 142 posts
Armorama: 137 posts
Posted: Friday, December 01, 2017 - 01:28 AM UTC
Quoted TextHA.......
JohnA
Gaz
JohnDoe4th
KitMaker: 142 posts
Armorama: 137 posts
Posted: Friday, December 01, 2017 - 01:37 AM UTC
Before you edit again....![]()
Thanks for the Info! I'll see if hobby lobby cares it. Ill give it a try BUT not over do the chipping. There's not a whole lot of pictures that shows the inside of the Greif, that shows any chipping or fading from the
JohnA
Removed by original poster on 12/02/17 - 19:08:22 (GMT).
iowabrit
KitMaker: 585 posts
Armorama: 557 posts
Posted: Saturday, December 02, 2017 - 12:12 AM UTC
Posted: Saturday, December 02, 2017 - 01:52 AM UTC
Steve,
Great choice for the campaign! I was hoping to see at least one of these done.
Gaz
Gaz
Posted: Saturday, December 02, 2017 - 06:39 AM UTC
Steve,
Interesting choice.
Interesting choice.
Posted: Sunday, December 03, 2017 - 02:38 AM UTC
Well my Panzer IV Ausf. D Tropical is about finished. Assembling the tracks now. Once I have them dry fitted I will start the painting process.
Here are a few shots I taken this afternoon.
Next post should be in color.
