I have been able to get some modelling time and managed to sort the tracks out on the A13. I did the one side and it was quite successful...
Using the other side here is how I did it...
Firstly the resin wheels were cleaned up and a brass axle attached...
Then the location holes were made in the side of the hull...
The wheels were then glued in place...
Next was cleaning up the tracks from the S-Model kit to use here, I did the top run first...
After cleaning up the top run the idler and sprocket were just push fit to ensure that the tracks were correctly positioned, once that was achieved the idler was glued in place...
The track was glued along the tops of the road wheels and finally the sprocket was lined up with the track and, when correct, glued in place...
Now the lower run of track was prepared, the wheels removed and the excess pared down using a sharp blade, finally being filed smooth...
The lower run of track was then added to the road wheels...
All that remains now is to replace the few guide teeth that got damaged in the operation and then it is on to the upper hull. Here it is push fit on the lower hull...
I shall be getting the upper hull sorted over the next week and hopefully have it fitted.
Thanks for looking, all comments welcome.
All the best,
