Comments Welcome on the following:
The headlight is supposed to be closed. I thinned the plastic made it open.
Fixing of Jack (with handle end pointed inwards)
Cleaning rod position inverted, Cleaning head pointed towards rear.
This was supposed to be an OOB build to get back to modeling after nearly 5 years. so comments welcome on areas of improvement. Sorry for the grainy photos. ISO 1600
because of lighting....
Used Tamiya Acrylics, Pledge and final misting clear coat using Mr. Color Flat (with leveling Thinner). So far no issues. If I want to try white wash, Can I spray Hair spray now and then Tamiya white? Is this sequence correct? Guidance please....
[/quote]
Yes, you have the right sequence. Just be aware different brands and amount applied can effect your results. I practiced on some extra plastic squares I had that I clear coated. Then tested different dry times with the hair spray before applying the paint.
your earlier pics came out fine also, just to touch on that.
look foward to your final outcome.
