I had planned on posting the build in one go, showing it from start to finish. Just something a little different. I ran in to a bit of a problem so I'll go ahead and post what I have until I can fix it.
I'm building CyberHobby's Sd.Kfz.250 Neu (9149). It's okay looking. It comes with a figure set...Armored Recon Wiking Division (Hungary 1945). It also comes with PE doors for the exterior storage bins. Of course, indie tracks.
I began by pre-painting the lower hull, roadwheels, and some of the fighting compartment.
I started with the multi-piece lower hull...which I dislike. Fit was not great...note the gaps. In hindsight I should have placed the driver's firewall to act as a jig to set the sides. As is, they are angled inward at the top a bit. It would have made placing the fighting compartment, firewall, and driver's seats easier.
Suspension arms are delicate...really delicate. And they seemed determined to avoid lining up.
Once I got that setup, I turned to the tracks. They are indie links. The U-shaped links fit together. You add the rubber track pad and it covers the connection points. If you are careful, you can make them workable. As an aside, these tracks are similar to Zvezda's but the rubber pads fit alot easier.
Used two wooden sticks as a guild. I placed 5-7 links and then added the rubber pads. It went quickly and they look good.
I painted the tracks using Rustoleum dark gray auto primer. I like the graininess and the texture it gives them...it also works well for tires.Tracks mounted well.
I didn't get a picture but I will dry-brush them heavily with red-brown, then a light drybrush of steel. The rubber pads will get painted Tamiya Dark Gray.
Fighting compartment components assembled. Some had been pre-painted. I went ahead and painted the side interiors.
I went back and assembled the front suspension.
The instructions for the driver and radio operator's vision blocks are vague. It would have been nice to position them open. Maybe mold them in clear styrene or with the armored glass clear and separate parts.
The intake grills are typical nylon mesh. PE would have been nice. I added a styrene strip to back them and give added support.
Front fenders went together easy. I left off the pioneer tolls and convoy marker posts until later.
Fighting compartment side walls. Dragon filled the sides with raised position lines for heaven knows how many variants. I forgot to do it before I painted...that's my little mess-up I spoke about earlier. The cover for the storage bin...I would cut that off later and just have it open. I also would change out the ammunition holder for the MP40 for two infantry MP40 ammo pouches. That's just a little quirky detail I wanted in there.
Inside upper section of the fighting compartment mostly assembled and base painted. I added the instrument panel and radio. I left the rifles out of the rifle rack until they could be painted.
Side walls added to hull. Rifles added. You can see the canvas MP40 pouches. I added two gasmasks and an ammo holder for the MG42. I probably will add a MP40 from the spares. Spare armored glass painted. Seats painted and you can see where I cut the storage box cover.
Also, I have built a coupel of the Dragon/CyberHobby halftracks. Fit has always been a problem. I test fit the top and found that the firewall needed to be notched behind the radio so the top can fit properly.
Anyway, that's where I am. I have to go back and try to remove the raised locator lines on the side walls. Other than that, assembly should wrap up soon-after. I probably won't add a crew or build the supplied figures. I have plans for this for a project.
