OK so as the Floyd-fueled tram rolls on (despite groans from rockers in the back row no doubt) the cabs got tidied up & finally benched, their windows & retaining frames can wait until later because…
…the compartment windows must be done to keep up some momentum on overall progress. As laborious as Tram 1, this side alone taking too many hours over several days…
Improvement #’s whatever were to make the frames slightly finer & the outer window ledge more accurate.
I managed to slightly improve technique for making the frames & frame-surrounds by ditching the ruler altogether. Although blessed with good eyesight (needing just 1.5 reading lenses for close work according to a recent eye test) some days I can’t seem to measure my way out of a paper bag due to some kind of dyslexia reading millimeters off a steel ruler. So I just put each styrene strip against the framework & marked/cut it directly instead. Alas this still didn’t eliminate slight variations of typically 0.5mm which means each frame only fits perfectly in its own surround, so they all have to be individually numbered again. If I was enjoying this more I might be amused that a side-effect of ruler-less marking is that the frames & panes fall out under gravity, but I’m gambling a couple of layers of primer & paint will wedge them in place. Reminds me of an ancient joke about not telling the difference between putty & vaseline & the windows falling out, but that’s not important right now.
For late-comers to this project the frames need to be glue-free/removable, because in the diorama narrative the windows on at least one side of this tram will need to be replaced (half way through the final photo-shoot) by alternates shattered by the grenade blast, which is why I needed to test this product early…
The Limonene didn’t stick but PVA/Elmers works perfectly. The picture reference shows blast damage on ordinary glass in an office block & I’m assuming inter-war tram glass was no different…
Child’s play, just throw any old shards into a frame in 2 minutes right? Well no, this first trial took over an hour & I still need more practice to make it look right, there’s a whole world of shattered-glass dynamics to discover…and then replicate for 6 or 7 more panes with reasonable uniformity yet also variability. The damage had two causes, pressure wave plus shrapnel…it’s just occurred to me this means I’ll also need to inflict shrapnel hits on the coachwork & woodwork mid-shoot. Ouch, that realization’s about as welcome as a fart in a spacesuit because it’ll mean using some rough handling on a relatively fragile structure at a critical moment. Hmmm…
Artefakt product review: Easy to glue, trim, and scratch cracks onto - you’re the ultimate judge regarding appearance & how I’ve used it, but I’m giving it 10/10 as a great diorama accessory
