So far I have built mine with the side hull plates showing the "lip" extending over the rear plate. I used the rear plate without the split hatch as I chose to use the 1 hatch option. Now will I still need to use the fillets or do I leave them off?
So far as I can tell, the "fillet" just behind the fighting compartment is consistent for WWII era SU-100, even the late ones. I have seen the pictures of the Aberdeen SU-100 but it appears this is a post-war Czech made vehicle. There is also the shot of the Mongolian SU-100 but this one has T-54/55 roadwheels, making it also post-WWII manufacture. I would go with the fillets.
Now whether I do use them or not, is it correct to use the square type front fenders or do I need to use rounded ones. The squared off fenders appear in 1945 from the sources I have seen. They may be earlier, but I know they were in use by Jan. 1945. Both fender types are seen in 1945 and post war.
The manufacture went something like this (this is just a rough outline so forgive me if I screw up a detail or two):
SU-85 is put into production in 1943.
When the T-34/85 starts production, SU-85 production is changed to SU-100 production. Demand for the tank destoyers meant that the early SU-100 were built on some of the last production SU-85 hulls (with the split rear casement hatch) and evidence suggests that some SU-85 were regunned with the 100mm D-10S.
SU-100 production is streamlined and the split rear casement hatch is simplified to just a single hatch. Sometime during production the front fenders switch from curved to squared off.
So there is a lot of room for almost ANY combination of features considering that there were over 2,335 built by July 1945.
I hope that clears up some of the issues. If anyone has better info, please post it.
