Matchbox Nostalgia Campaign
tread_geek
KitMaker: 2,847 posts
Armorama: 2,667 posts
Posted: Sunday, January 17, 2010 - 05:01 PM UTC
WOW! Looks like we're off to a pretty good start.
@Stefan
Allright, here we are... Was a bit too optimistic about finishing today, the kit is more complex than I thought (or than I expected from a Matchbox kit).
Hope I won't disapoint you there Jan, here we are:
Great progress on a kit that many of our larger scale brethren would think could be built in an hour or two. I read a lot on Braille Scale sites and there are plenty of warnings to not take the AVRE lightly. Looks like you are doing a very credible job.
@AJB - Don't be so down on yourself, this is supposed to be about FUN and a bit of learning. It's also about passing along information. What you may disclose may help Toby with his Challenger. Then again he may offer you some insight.
@tommytanker - Gary, glad to hear that you are up and running. I have the Priest so I will be most interested in your progress. Good thing that you aren't building the Matchbox M-24. Wouldn't want you to mix up the parts between that build and the 1:1 scale version.
Jan
Andronicus
KitMaker: 391 posts
Armorama: 321 posts
Posted: Monday, January 18, 2010 - 03:06 AM UTC
I too will be building the M24 Chaffee,
This will be my first kit build. Pretty much ever! (if you ignore the glue-encrusted 251 with Flamethrowers I built whan I was 9!)
I've been gradually collecting 1:72/6 kits for the last couple of years alongside building other large-scale scratch projects, asking lots of questions and researching the general art of kit-building. I figured joining this campaign would be a good way to finally get started.
Andrew - I'll be following your progress particularly closely as I'm sure I'll learn a lot (no pressure!!). I've had a good look at my kit - how do you propose to deal with the decal on the rear that partially covers the grille? I was wondering about making a mask and spraying the star on - the photo on the instructions just looks ugly.
Our flat is on the market and - as if it knew - I'm suddenly faced with unexpected DIY jobs. Therefore my participation might be rather delayed and a little sporadic. But I'd like to wish everyone good luck.
All the best
A
Some progress on the M-24. Assembled it and got the primer on today. I'm going to have some difficulty getting the idler and drive sprockets under the track guards...but the only other option was to put the guards on after painting- which should be tomorrow.
Andrew
casualmodeler
Hame, Finland
KitMaker: 702 posts
Armorama: 665 posts
Posted: Monday, January 18, 2010 - 03:21 AM UTC
Hi Jan!
I decided to start building Char B1 bis & Renault FT-17 duo. Some progress during yesterday, photos follow later, when I remember take one first.
tread_geek
Posted: Monday, January 18, 2010 - 06:37 AM UTC
Greetings all. We now have 10 people committed to and/or actually building. I hope that any problems that arise in your builds are few and minor.
@ Andronicus - Another M-24 will certainly enhance our groups recon abilities. The M-24 is a nice little kit and should go together with minimal difficulty. The nice thing about having several people working on the same kit is how they might help each other and learn new things.
@Kimmo - This is another kit that I'll be fascinated to see come together. The Ft-17 will be particularly interesting as I envision it's absolutely tiny. Perhaps on a par in size with the old Fugimi Pz I.
Jan
newfish
KitMaker: 2,329 posts
Armorama: 2,110 posts
Posted: Monday, January 18, 2010 - 08:03 AM UTC
Well guys throw my name into the hat
I'm building these pups
tread_geek
Posted: Monday, January 18, 2010 - 04:58 PM UTC
Welcome Jaymes. Your callsign has been added to the chart and your selections noted as Definite. We now have three transporters and one M40 short of a battery. With your enlistment this brings our proud number to 34. I may be presumptuous but I see a Feature about this campaign if we get enough builds completed.
Jan
ianclasper
KitMaker: 227 posts
Armorama: 141 posts
Posted: Monday, January 18, 2010 - 05:28 PM UTC
I have made start to my Churchill AVRE
I have run into a small problem. Steps 12 and 13 show the installation of the drive and return sprockets, two number 29 at the rear and two number 30 at the front.
Now this does not seam to be right as I cannot fit these parts together, should this be 29 + 30 in all positions ?
Can someone give me some guidence
Ian
Dangeroo
#023
Zurich, Switzerland
KitMaker: 2,058 posts
Armorama: 1,656 posts
Posted: Monday, January 18, 2010 - 07:36 PM UTC
Ian
Interesting, I didn't even notice... I just got them all off the sprue and added one of each on each end. Filed off the locationg lugs on the wheels though, as I couldn't get a good fit at all. Cleaning up the attachment points from the drive sprocket teeth was a PITA though, used a triangualar file to get the teeth back.
HTH!
Cheerio!
tatbaqui
Staff MemberNews Writer
Metro Manila, Philippines
KitMaker: 2,713 posts
Armorama: 2,451 posts
Posted: Tuesday, January 19, 2010 - 03:15 AM UTC
Good to see everyone's off to a good start. Started work on the Jagdpanther today:
Well here's one for the nostalgia trip. I guess its just correct for Revell to take out the Matchbox markings, but they have left the originial kit no:
Still have to fix the bad fit on the front hull, somehow couldn't get it aligned. Drilled a hole for gun -- this is allowed, right?
Now for a test fit:
With Big Brother:
Tat
tread_geek
Posted: Tuesday, January 19, 2010 - 06:06 AM UTC
I just had a look at the original plans for the A.V.R.E. and I was quite surprised by the number of parts and what will be involved to build that kit. You people doing this kit have to be pretty talented masochists. So much for a simple, quick build.
@Tat
Some really quick progress there on your Jagdpanther. The picture with "the big brother" and the "PK 80" on the sprue are some nice inspirational touches. As to your question about the boring out of the gun barrel, I believe that this was covered earlier in the thread and is totally fine and acceptable. Little things like that or opening closed hatches/doors, adding some storage or small details are all covered by the original rules. If in doubt it doesn't hurt to ask.
Jan
Smartin
Zuid-Holland, Netherlands
KitMaker: 48 posts
Armorama: 40 posts
Posted: Tuesday, January 19, 2010 - 06:40 AM UTC
Hey Ian,
Do you have matchbox or revell?
I have a revell kit and mine says in step 5 and six to put 29 and 30 together....
Martin
ianclasper
KitMaker: 227 posts
Armorama: 141 posts
Posted: Tuesday, January 19, 2010 - 07:28 AM UTC
Hey Ian,
Martin
Mine is the a matchbox kit with what appears to be "Japanese" instructions.
I think that Revell have corected the instructions.
Thanks
Ian
Capt_Concussion
KitMaker: 40 posts
Armorama: 39 posts
Posted: Tuesday, January 19, 2010 - 07:33 AM UTC
Got the Priest built, primed, and a base coat started.
Now for the hard work!
Couple of pics...
tread_geek
Posted: Tuesday, January 19, 2010 - 05:10 PM UTC
Couple of pics...
Trying to sneak this in without us noticing! Looks like a very nice build and for some reason I like the way the tracks sit in the top picture, especially nice around the sprocket. You're off to a fine start but as you mention the difficult (almost fun?) part begins with the detailing.
Jan
tatbaqui
Posted: Tuesday, January 19, 2010 - 09:56 PM UTC
@Tat
Some really quick progress there on your Jagdpanther....
Thanks Jan, and yes it builds quite fast. Have tested the tracks, but there seems to be a gap in the joints when stretched. Still have to find a way to get some sag -- if possible. Filled up the the hull gaps. So far its ready for priming. Here are the latest:
Tat
sabredog
Western Australia, Australia
KitMaker: 607 posts
Armorama: 599 posts
Posted: Tuesday, January 19, 2010 - 11:52 PM UTC
Watch the Revell M40 re-pop as the lower chassis plate in my kit was warped. I got most of the problem sorted with some clamping and CA.
Dangeroo
#023
Zurich, Switzerland
Posted: Wednesday, January 20, 2010 - 01:18 AM UTC
Definitely, I checked yesterday.
Mine is almost ready for painting, all it needs is the "rigging" but this will probably be more complicated than it looks...
Nice builds everyone!
Cheerio!
Stef
majjanelson
South Carolina, United States
KitMaker: 1,355 posts
Armorama: 979 posts
Posted: Wednesday, January 20, 2010 - 06:18 AM UTC
For you guys working on Churchill AVREs, have you seen these Line Drawings showing the Churchill ARVE Baily Bridge Rigging?
I do not remember where I found these, so I apologize for not citing the proper source.
tread_geek
Posted: Wednesday, January 20, 2010 - 07:55 AM UTC
Tat, perhaps the tracks may be a job for a gap filling super glue. From pictures I've seen the track rests on top of the road wheels in most cases. Another method I've seen a Braille scale builder use on these kind of tracks is to use a metal pin to force the track down on the wheels. You drill a hole in the body, super glue in the rod so it keeps the track down. Suitable weathering should be able to disguise the pin when done.
Thanks for the warning, Michael. I had a look at mine and it "seems" okay but looks can be deceiving.
Stefan, I think that the rigging may take longer than the build so far. Remain patient and good luck.
Jan
firstcircle
KitMaker: 2,249 posts
Armorama: 2,007 posts
Posted: Wednesday, January 20, 2010 - 11:20 AM UTC
The Funnies by Geoffrey W Futter was a series that originally ran in Military Modelling in the 1970s, maybe early 80s. I remember it did seem to go for an interminably long time - for my child like perspective of time anyway. I think it must have become a book afterwards. Yours looks like a German editiion.
A message for my comrade Puma builder - if you haven't started yet. Those suspension units are very delicate. The wheel connectors present a big lever against the thinness of the joint to the swinging arms. I broke one. .
Sabot
KitMaker: 12,596 posts
Armorama: 9,071 posts
Posted: Wednesday, January 20, 2010 - 11:33 AM UTC
I dug through my stash of Matchbox kits and came up with these. I realized I had several Stuarts (3 or 4) and a couple of Krupp Protz. I still haven't decided which kit to enter.
Capt_Concussion
KitMaker: 40 posts
Armorama: 39 posts
Posted: Wednesday, January 20, 2010 - 11:45 AM UTC
Jan
Thanks Jan,
Building this old Matchbox kit shows how lucky we are with the more modern kits.
I think we all know that the tracks will be the weakest point of all the matchbox builds, so I'm pretty pleased with how they turned out on the Priest.
I'm looking forward to making the best of this old kit.
Incidentally, does anyone know anything of the Italeri 1/72 'fastbuild' Priest. Many UK sites have this slated for release Nov/Dec 2009, but no sign of it anywhere. It could provide a good basis for a kit bash/scratchbuild opportunity to make a 1/72 (not 1/76) Priest - a very obvious omission from the current Allied 1/72 kits.
tread_geek
Posted: Wednesday, January 20, 2010 - 11:50 AM UTC
Show off! I vote for either the Stuart or the Panther. Axis stuff is truly lacking.
Jan :[]
Capt_Concussion
KitMaker: 40 posts
Armorama: 39 posts
Posted: Wednesday, January 20, 2010 - 12:29 PM UTC
Go for one of the Stuarts. Two reasons:
1) I don't think anyone else is building one
2) There's not enough Allied armour builds around!
Just my tuppence worth
Sabot
Posted: Wednesday, January 20, 2010 - 12:31 PM UTC
I have a few others in my inventory, just did not locate the boxes among the stacks of moving boxes. The ones I have but did not find are the LRDG, M40 GMC, M16, T-34/76, Puma, Pz III Ausf. L, JdgPz IV L/70 (I'd really like to locate this one to build), M7 Priest and the Humber (2nd choice to build).
