Well guys I seem to be on a roll as I took another day off from work due to the snow so here is the next installments of my Tiger Progress.
1st up is a pic of the tracks.. It doesn't show to well in the photos, but its basecoat is rust, oversprayed to dull down with thinned africa braun. then I went over it with a grafite pencil.. It doesn't show up that well esp in photo's so I am thinking to drybrush the area's with steel... what does everyone else think?
The next two photo's show the camo applied.. I used Dunklegrun and burnt Sierria. I think I may have got too much of the red on the turrent roof but we will leave it be and see what happens after all the filters and weathering.
It's not all that easy to get thin lines on a 1/72 scale kit. esp for someone like me who has only moderate airbrushing skills. But all in all I don't think it looks to badly out of scale.
camo was sprayed at 5 to 8 lbs pressure using thinned down Model Master paints. Anyone have any tips, I'll listen.. lol
laters.
BTW here is a link to my build log
My Tiger Build Log
Tiger Campaign
Posted: Thursday, January 27, 2011 - 02:45 AM UTC
spacewolfdad
KitMaker: 642 posts
Armorama: 593 posts
KitMaker: 642 posts
Armorama: 593 posts
Posted: Thursday, January 27, 2011 - 03:06 AM UTC
Hi Delbert,
Looks good to me. The only way I have found to spray thin lines on small subjects is exactly what you have done - low pressure and thinned paint. It is a good idea to keep a record of your mixes, so that when you find the perfect blend you remember what it was you did right! (Speaking from experience here) I don't know what your next stage is, but after the initial camo I usually mist the model with a mix of base colour and thinners at a ratio of 20:80, this tones down the colours and also blends everything in. If you want to give this a go I would recommend practicing on an old model first. Here is a Panther that I have at the same stage as you have reached, with the thinned down paint mist applied.
Hope this is some help. All the best,
Posted: Thursday, January 27, 2011 - 04:07 AM UTC
Thanks for the feedback. I'm planning to fade the model but first I am going to apply the markings, and maybe some of the tools.so they will fade with the paint. I then have several other things I'm going to try with the finish.
I don't know exactly what the finished tank will look like, but I know I'll have learned some new (to me) stuff.
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Thursday, January 27, 2011 - 04:26 AM UTC
Some great work going on here keep up the good work
@ Delbert, Your tiger is looking great considering that it is 1/72 the tracks look fine to me. I had the same turret problem, sprayed too much green, went back over it with some more dunkelgelb
@ paul, hey thanks for that tip I will try that on a practice build
Kiwi_Modeller
KitMaker: 188 posts
Armorama: 121 posts
KitMaker: 188 posts
Armorama: 121 posts
Posted: Thursday, January 27, 2011 - 11:35 PM UTC
bit more done, slow but steady, rear bulkhead and engine sides painted an in.
seats in.
then we get to build a nice gearbox.
waste of time painting it cause then we hide the damn thing totally
gearbox nearly complete and dry fitted to check clearances.
tomorrows goin to be painting gearbox and installing it then start on the engine, thats gonna take a couple days as there is about 6 pages of the manual dedicated to builfing it and installing it (after its painted of course).
all whees painted , just a bit of weathering an paint tracks then i'll stick em on to get it on its feet.
cheers,
Graham
seats in.
cheers,
Graham
GregCloseCombat
KitMaker: 2,408 posts
Armorama: 2,394 posts
Posted: Saturday, January 29, 2011 - 04:51 PM UTC
Nice build logs everyone
Delbert - I would vote to drybrush some steel on the teeth at least for more contrast.
Paul - good tip for the camo /airbrush and Delbert for low pressure as I have problems with this.
Graham - I like the colors you're using. I think when you're done, you should take a Dremel and cut some holes for viewing all that interior on one side like they do in the tank museums.
I'm waiting for barrels still and working on other projects for now
Kiwi_Modeller
KitMaker: 188 posts
Armorama: 121 posts
KitMaker: 188 posts
Armorama: 121 posts
Posted: Saturday, January 29, 2011 - 06:19 PM UTC
hey Greg yeh they give you clear hull top and turret so im still thinking of doing half painted and the other half leave it clear.
least that way it'll stop it gettin full of dust lol.
cheers,
Graham
cheers,
Graham
Kiwi_Modeller
KitMaker: 188 posts
Armorama: 121 posts
KitMaker: 188 posts
Armorama: 121 posts
Posted: Saturday, January 29, 2011 - 11:15 PM UTC
small update, gearbox painted and in (not glued yet)
Engine underway, figured i better photo it now.
before i stick this dirty great aircleaner on lol.
cause once i do ya can see bugga all
cheers,
Graham
cheers,
Graham
MAMOOTH
Yucatan, Mexico
KitMaker: 45 posts
Armorama: 43 posts
KitMaker: 45 posts
Armorama: 43 posts
Posted: Sunday, January 30, 2011 - 02:35 PM UTC
Hi guys, how are you? i hope enjoying the campaign like me do. This are 5 photos of my project. I am going slow , i finished the upper hull, and part of the frontal, this last one did not fit well to the chassi i will need to use putty, i hope to finish next weekend and start the painting.
MAMOOTH
Yucatan, Mexico
KitMaker: 45 posts
Armorama: 43 posts
KitMaker: 45 posts
Armorama: 43 posts
Posted: Sunday, January 30, 2011 - 02:41 PM UTC
GewoonWouter
Antwerpen, Belgium
KitMaker: 227 posts
Armorama: 123 posts
KitMaker: 227 posts
Armorama: 123 posts
Posted: Monday, January 31, 2011 - 07:21 AM UTC
great progress here on the campaign fella's. Like where these builds are going a lot. Keep up the good work I would say.
I should continue with my Tiger too ey
cheers
cheers
meaty_hellhound
KitMaker: 786 posts
Armorama: 753 posts
KitMaker: 786 posts
Armorama: 753 posts
Posted: Monday, January 31, 2011 - 07:42 AM UTC
hi guys,
been enjoying everyone's work on this great campaign. here's my start on a King Tiger:
it's for a diorama i've begun, more pics of the KT's final build here.
keep those tigers rolling. cheers, bd.
vonHengest
KitMaker: 5,854 posts
Armorama: 4,817 posts
Posted: Monday, January 31, 2011 - 08:50 AM UTC
Builds are looking great as usual guys! I still have about 4 or so projects to complete before I can get started on mine, but I'm looking forward to it
spongya
Associate Editor
Budapest, Hungary
KitMaker: 2,365 posts
Armorama: 1,709 posts
Posted: Monday, January 31, 2011 - 10:47 AM UTC
Small Tiger, small progress.
I really like the white-on-gray winter camo of the early Tigers, so, without being very accurate, I'm trying to backdate this kit. Of course there'll be plenty of inaccuracies, but I just can't face to buy another Tiger kit, so everyone will have to live with them
thebear
Quebec, Canada
KitMaker: 3,960 posts
Armorama: 3,579 posts
Posted: Tuesday, February 01, 2011 - 12:09 PM UTC
Good stuff guys ...I got to get back to my kit this week ...
AgentG
Nevada, United States
KitMaker: 1,109 posts
Armorama: 1,095 posts
Posted: Friday, February 04, 2011 - 02:11 PM UTC
I'm digging this one for sure. I am finally to receive my AM zimm which has been backordered for a month.
My Pershing is complete for the KoWar Campaign, and the Afrika Korps Campaign doesn't start for a bit.
So looks like I'll be starting on my Tigger!
G
G
GregCloseCombat
Posted: Friday, February 04, 2011 - 03:39 PM UTC
Nice builds everyone. Should be a great gallery at the end.
Kiwi_Modeller
KitMaker: 188 posts
Armorama: 121 posts
KitMaker: 188 posts
Armorama: 121 posts
Posted: Friday, February 04, 2011 - 10:46 PM UTC
gday guys, well i got the tracks on temporarily they protect the wheels lol.
after two an a hlaf days the engine is painted an in, i was dry fitting it to make sure all the pipe work lined.
damn lucky it did cause after getting it in there the bloody thing would'nt come out , so its there to stay now.
still got some plumbing to add, those rubber hose (the bigger ones) are crap there in two pieces so dont bother tryin to handle em too much cause they just keep falling apart so i just carefully superglued em together an then in place , dont know yet what paint does to em but since they were probably plain ol black rubbrt might just leave em as is.
next comes the really slow bit makes 80 odd rounds of ammo plus the racks, radios, oh man the list is too big LOL.
im thinking theres still another month on the hull alone.
cheers,
Graham
cheers,
Graham
Posted: Saturday, February 05, 2011 - 02:52 PM UTC
howdy all
Just posting another pic of my 1/72 scale Tiger with zimmermit...
this is just a pic showing the decals on the tank. This just goes to show that
Solveset works.
later all
plus i've been experimenting with my camera and this pic came out very nice..
laters again
Solveset works.
later all
laters again
Posted: Sunday, February 06, 2011 - 01:34 AM UTC
howdy
Yet another progress pic of my Tiger in 1/72..
This time taken after the tools are painted but before the weathering begins..
laters.. waiting for paint to dry....... lol
spacewolfdad
KitMaker: 642 posts
Armorama: 593 posts
KitMaker: 642 posts
Armorama: 593 posts
Posted: Sunday, February 06, 2011 - 02:29 AM UTC
Hi Delbert,
Looking really good, the decals turned out well. I look forward to the next stage.
All the best,
All the best,
TankTurk74
Missouri, United States
KitMaker: 15 posts
Armorama: 14 posts
KitMaker: 15 posts
Armorama: 14 posts
Posted: Monday, February 07, 2011 - 04:07 PM UTC
Howdy fellow Tiger fans, I started modeling again this summer after a number of years and have been having a lot of fun building WWII tanks, mostly German of course. Anyway, I have been checking out this site and others and have really enjoyed and been amazed by all the great info and models being built out there. I just recently discovered these campaigns and think it would be a lot of fun to participate. My question is I would like to enter this campaign with a Tiger I just started last week, the new Tamiya1:48 Afrika Corps tank. I already have it mostly built, I was off work two days last week with this blizzard that hit Missouri. I did not take any pics of it still on the spurs but I assure you I just started it last week and I only bought it on new years eve. Anyway I do have a DML Tiger in the box still which I could also get to in time, not to mention the other 2 Tiger kits in the stash. Thanks, Semper Fi
ltb073
Posted: Monday, February 07, 2011 - 04:26 PM UTC
[quote My question is I would like to enter this campaign with a Tiger I just started last week, the new Tamiya1:48 Afrika Corps tank. I already have it mostly built, I was off work two days last week with this blizzard that hit Missouri. I did not take any pics of it still on the spurs but I assure you I just started it last week and I only bought it on new years eve. Anyway I do have a DML Tiger in the box still which I could also get to in time, not to mention the other 2 Tiger kits in the stash. Thanks, Semper Fi[/quote]
Hi Adrian,
Welcome to the sight. You got my vote to join in. and while ya at it might as well build the other 3 Tigers as well We don't sleep we built
Hi Adrian,
thebear
Quebec, Canada
Posted: Tuesday, February 08, 2011 - 09:24 AM UTC
Welcome Adrian... The more the merrier!
TankTurk74
KitMaker: 15 posts
Armorama: 14 posts
KitMaker: 15 posts
Armorama: 14 posts
Posted: Wednesday, February 09, 2011 - 01:10 PM UTC
Thank you all for the warm reception. I will try and get some pics posted soon of the DAK Tiger 1:48 plus some others big cats I have been working on. Thanks again.
