Tank Destroyer/SPG Campaign
Dragon164
#226
British Columbia, Canada
KitMaker: 1,909 posts
Armorama: 1,066 posts
Posted: Sunday, November 18, 2012 - 07:02 PM UTC
Thanks Phil!
I have some Vallejo Russian green surface primer on both lower hulls and the insides of all the running gear(it's hard to see in the pics) once I finish the uppers and tracks I can start with the finish coat.
Did the other side tanks of both and a bit of PE.
Cheers Rob.
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Monday, November 19, 2012 - 03:58 AM UTC
Hi Rob
I can´t wait to see those two nasty buggers get going.
Somehow they remind me of my brother and I
PvtMutt
Missouri, United States
KitMaker: 614 posts
Armorama: 601 posts
Posted: Monday, November 19, 2012 - 05:43 AM UTC
Hey Cam i'm building mine as a early model and they didn't have the screen skirts.
Tony lee
PvtMutt
KitMaker: 614 posts
Armorama: 601 posts
Posted: Tuesday, November 20, 2012 - 11:08 AM UTC
Tracks in place
They do make a difference.
Tony lee
TMoon
#152
KitMaker: 487 posts
Armorama: 441 posts
Posted: Tuesday, November 20, 2012 - 02:03 PM UTC
Here are some in progress photos and an appeal for help.
How do I correct the warp of main hull????
Any suggestions?
Here is the rest of the model.
Thanks in advance for any help!
Tom
SaxonTheShiba
KitMaker: 1,233 posts
Armorama: 557 posts
Posted: Tuesday, November 20, 2012 - 02:37 PM UTC
Tom, in the past I have fixed hull warpage by using sheet stock columns and spacers inside the hull to either "pull in" or "push out" the warped areas and make everything square. Basically, just make a lattice work inside the model and use the sheet stock supports to square everything up. You can also use thin plastic shims to expand the spars or columns as needed. Once you have everything in place apply some CA glue and accelerant and everything should be nice and strong.
Regards, Ian
shorty53
#330
KitMaker: 175 posts
Armorama: 72 posts
Posted: Tuesday, November 20, 2012 - 08:29 PM UTC
Hi Tom.
I had the exact problem with the M-10 I’m building. I put a heap of glue on and used a couple of clamps when I attached the engine cover (C6), this piece helped strengthen the hull and straighten things up a bit. I then attached the rear plate (C2 I think?), I glued one side and let it dry over night then glued and clamped it on the other side the next day, and this seemed to just about fix the issue. There was only a small warp left which was rectified when I glued the upper hull to the lower hull, I used lots of glue, put a heavy weight on top of the upper hull and left it over night.
Will post a pic of my build soon.
Bluestab
South Carolina, United States
KitMaker: 2,160 posts
Armorama: 1,906 posts
Posted: Wednesday, November 21, 2012 - 07:08 AM UTC
Tom,
Wow that's some nasty warping. Try clamping the rear to something flat and dipping it in hot water. Given the thickness of the plastic you might have to repeat the process a few times. It won't fix it outright, but it'll hopefully straighten it enough to make it easier to fit the to rear plate and engine deck plate.
Good luck.
PvtMutt
KitMaker: 614 posts
Armorama: 601 posts
Posted: Wednesday, November 21, 2012 - 07:24 AM UTC
She's headed to the paint shop:
See Ya Later
Tony lee
Cam
#275
KitMaker: 174 posts
Armorama: 141 posts
Posted: Wednesday, November 21, 2012 - 11:31 AM UTC
Finished painting my EBR-10, now to paint up an appropriate crew.
Overall this kit was a fun build. I can't understand the variation in detail in the kit. There is minute detail in some places and then major things missing in another.
SaxonTheShiba
Armorama: 557 posts
Posted: Wednesday, November 21, 2012 - 12:03 PM UTC
Cam, great job and that is really a cool looking vehicle. Very nice, indeed.
Best wishes, Ian
SaxonTheShiba
Armorama: 557 posts
Posted: Thursday, November 22, 2012 - 07:27 AM UTC
Well the M-1134 TOW STRYKER is a wrap and posted up in the gallery. The vehicle was weathered with a variety of MIG and CMK pigments and Tamiya and Trumpeter stowage was used to accessorize the exterior. Vehicle depicted is a TOW STRYKER from "Killer Company", 2nd Stryker Cavalry Regiment, Germany.
This has been a very enjoyable campaign and everybody's models have been really outstanding. Enjoyed it...as always.
Best wishes, Ian
Dragon164
#226
Posted: Thursday, November 22, 2012 - 09:25 AM UTC
Ian,
Looks Great!
Cheers Rob.
SaxonTheShiba
Armorama: 557 posts
Posted: Thursday, November 22, 2012 - 11:02 AM UTC
Thanks Rob!!!!!!! Lookin' forward to your dual SU's !!!!!
Best wishes, Ian
WARDUKWNZ
Auckland, New Zealand
KitMaker: 1,716 posts
Armorama: 1,638 posts
Posted: Thursday, November 22, 2012 - 11:18 AM UTC
Cam ... Wonderful job on the EBR ..strange how the detail was there and not there ..its like they forgot about parts
Either way mate she turned out excellent and its the only one in the is campaign ,so glad to see this
Ian .. Dude ya nailed it ..love the paint work and the dirt is so nicely done .. seriously sweet work mate
Phill
SaxonTheShiba
Armorama: 557 posts
Posted: Thursday, November 22, 2012 - 11:30 AM UTC
Thanks Phil!!!! Trumpeter not withstanding, it was a fun build and I love those 8x8's.
Best wishes, Ian
Cam
#275
KitMaker: 174 posts
Armorama: 141 posts
Posted: Thursday, November 22, 2012 - 05:12 PM UTC
Nice build Ian, makes me want to do something modern. Rumors are that MENG is coming out with an AMX-30B, that would go with an EBR-10.
SaxonTheShiba
Armorama: 557 posts
Posted: Thursday, November 22, 2012 - 05:37 PM UTC
Thanks Cam! I would love to see a good AMX-30 kit come out. Very sleek tank and it would certainly compliment your EBR-10.
Best wishes, Ian
PvtMutt
KitMaker: 614 posts
Armorama: 601 posts
Posted: Saturday, November 24, 2012 - 08:57 AM UTC
Base color coat is on. I think it's GREEN
Only the Hungarians know for sure.
Tony lee
SaxonTheShiba
Armorama: 557 posts
Posted: Saturday, November 24, 2012 - 09:08 AM UTC
Very nice Tony! What a cool looking vehicle and a very crisp build.
Best wishes, Ian
Dragon164
#226
Posted: Saturday, November 24, 2012 - 02:21 PM UTC
Yes Tony that is an interesting vehicle! Well Done!
I have all the tracks for both ready that and a handfull of small parts for the SU-100 and I can finish off the base coat on that. Still some more PE to do on the SU-85 but it's coming along too.
Cheers Rob.
PvtMutt
KitMaker: 614 posts
Armorama: 601 posts
Posted: Saturday, November 24, 2012 - 02:51 PM UTC
Thanks guys
I would like to do the SU series one of these days myself Rob.
See you folks later
Tony lee
BBD468
KitMaker: 2,465 posts
Armorama: 2,383 posts
Posted: Saturday, November 24, 2012 - 03:12 PM UTC
Nice builds fellas, wish i had entered early .....
Tony - fantastic paint work buddy! Killer tank man...just cool as heck!!!
Gary
Dragon164
#226
Posted: Saturday, November 24, 2012 - 08:44 PM UTC
Ok,
Tracks done one side, then the other ready for paint.
At least one is.
Cheers Rob.
shorty53
#330
KitMaker: 175 posts
Armorama: 72 posts
Posted: Saturday, November 24, 2012 - 08:47 PM UTC
Update on my M-10, Hull is just about complete.
