Ok, I've gotten some work done on my M32B1! This is my first campaign, so if this is too much detail just let me know.
Started with the suspension. Instead of scraping 144 pop rivets off the sprue, I punched them with a Waldron sub-micro and .005" sheet, then attached with a drop of Tamiya extra thin (and for you mathmaticians out there, I did the fronts only!)
Then did the return roller mounting holes using a #76 bit in a dremel and a jig I made from brass sheet
I plan on making this the cargo for my Dragon Wagon (Build log here:
http://armorama.com/forums/196568#1646486 ) with a blown engine, so I may open up the hatches and add this (the engine, not the T-34!):
Also, not too keen on the empty driver's compartment, so I grabbed some pieces from a spare Academy Grant and modified it into a rudimentary interior based on photos from the Ampersand "Heavy Wrecker" book:
Hopefully good enough for what you'll be able to see through the turret and an open hatch or two!
Then added a little detail to the firewall
Had to fill/scrape a lot of ejection marks before I assembled the hull
Textured the cast final drive cover with Mr Surfacer 500, added some Archer casting marks based on a photo in Allied and Axis.
Very impressed with the engineering on this kit (my first Tasca) The places where the bolt strips attach even have the holes where the bolts would have gone?!?! That's crazy
Thanks for looking, more soon!
Terry
