Looking for ideas for what to 3D Print
MikeyBugs95
KitMaker: 2,210 posts
Armorama: 1,712 posts
Posted: Sunday, November 13, 2016 - 07:57 PM UTC
Mike,
Also note the 2 different bases that Gino posted.
The 2nd one pictured is a AM-7239E and the 1st one, which you made, is a AM-7239B model.
Is either more correct for the different radios or does it matter? Is either more common than the other? It shouldn't be too hard to model the E base out of the B base.
IN this case there might be a little confusion because we are talking about the antenna signal amplifier on the left side of the base rather than the audio amplifier which, l believe is located on the right side of the base.
I agree with Gino. Just let me know when you are happy with the SINCGARS and I will order some!
I'm pretty happy with the design currently. I'm just waiting to get in the set I ordered so I know it'll print correctly and without too many problems. I ordered it as "print it anyway" so no matter what, it'll print and they'll send it to me. This will speed up the process some but they won't notify me if the engineers think it won't print correctly.
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Sunday, November 13, 2016 - 08:01 PM UTC
Mike,
I have never seen the AM-7239E mounting base with the single radio. I have always seen the AM-7239B mounting base. It is usually for a two radio system, but can be used for a single radio mount as well. Also, either radio (ICOM or ASIP) can go in either (or any) base without modification. That is how the SINCGARS system was designed so it could easily be reconfigured for different scenarios or vehicles by adding or deleting components. It is basically plug and play.
Here's something else to think about. If you added another LS-671/VRC speaker, it would have the correct amount (4) for two complete radio sets. You would only need 4 handsets as well. The rest of the pieces are nice to have, but not needed for the SINCGARS setup. I guess the other two handsets could be used on the PRC-152/154 as well though. So maybe just add the speaker box.
MikeyBugs95
Posted: Wednesday, November 16, 2016 - 04:03 AM UTC
I can add the 4th speaker. What I might be able to do is remove 2 phones and replace them with that audio amp base. I could also make the second mount into a AM-7239E from the 7239B that it is now. So there would be a B and E model included. Not that the difference would be all that noticeable but it's a possibility.
Also, unfortunately it seems my first order was damaged or some other kind of unfortunate occurance occurred so that it had to be restarted. The status went from "In Production" to "Pre-Production" for some reason. I'm not sure why. I haven't been updated.
Posted: Wednesday, November 16, 2016 - 04:34 AM UTC
I vote for the extra speaker box and separate amp with its mount. I would also rather two of the AM-7239B mounts as they are the more common ones. Like I said above, I have never seen an AM-7239E mount in use, I've never actually seen one at all.
AmTrac1833
#431
KitMaker: 376 posts
Armorama: 311 posts
Posted: Wednesday, November 16, 2016 - 05:30 AM UTC
I ordered a small gaggle of these for myself. Would it be easy to tweak for 4 1523A/B/C/D instead of offering a pair of each type of SINCGARS?
We had the "older" radios in both stacks on the AAVs from about 1995 through around 2008 or 2010.
MikeyBugs95
Posted: Wednesday, November 16, 2016 - 09:45 AM UTC
Ok, I'll get started on that mount. It's the MT-6353.
I can make a basic set with just 1 7239 and either the A-D or E-F. I'll also make a set with the 1439s.
Epi
KitMaker: 3,586 posts
Armorama: 2,556 posts
Posted: Wednesday, November 16, 2016 - 10:22 AM UTC
The AM-7239C/D/E is able to be set up for data interface and networking. It also is interfaced with the EPLRS and PLGR.
Gino, maybe the reason why I saw more of the E models was because I was in a Battlefield Surveillance Brigade.
The AN/TPQ-36 had E;s in it, well at least ours did, I'm guessing it was to send info to the gun batteries and such via the radio's.
MikeyBugs95
Posted: Wednesday, November 16, 2016 - 11:37 AM UTC
Ok, so I think this is what could he a viable strategy offering all of these:
-Full original set with 2 AM-7239B, 2 RT-1523A-D, 2 RT-1523E, 4 LS-671, 1 PLGR, 1 DAGR, 4 H-250U or MT-6353, 2 AN/PRC-152 and 1 AN/PRC-154
-RT-1523A-D set with 1 AM-7239B, 2 RT-1523A-D, 4 LS-671, 1 PLGR, 1 DAGR and 2 H-250U
-RT-1523E set with the same as the A-D set but with 2 RT-1523Es
-RT-1439 set with the same and A-D and E set minus the PLGR and DAGR but including a new mount similar to the MT-6352.
Does this sound fairly acceptable or a good idea?
Epi
Posted: Wednesday, November 16, 2016 - 11:44 AM UTC
Your post looks like code Mike!
Your going to make a lot of guys happy, including me, when these are done and ready to purchase.
MikeyBugs95
Posted: Wednesday, November 16, 2016 - 12:13 PM UTC
When I was typing it it almost seemed like it! Almost like a foreign language. Especially at 1 AM!
And I certainly hope so. I aim to please as the saying goes.
AmTrac1833
#431
KitMaker: 376 posts
Armorama: 311 posts
Posted: Wednesday, November 16, 2016 - 08:39 PM UTC
I can add to the alphabet soup if you want to make an AAV specific (older) suite.
1x AM-7162
2x AM-7239
1x LS-671
1x H-250/U
2x C-11291
4x C-11133
1x C-11135
4x RT-1523 A/B/C/D (alternate "new" set would supplant two with E/F)
1x PLGR (alternate "new" set would supplant with DAGR)
Only thing missing is the EPLRS RT-1720C(C)/G
MikeyBugs95
Posted: Wednesday, November 16, 2016 - 09:57 PM UTC
Unfortunately I can't do an EPLRS. I can't find enough info on it to even start it. But I could do that AAV-specific set. Heck, I could do a lot of sets with what I have.
Posted: Wednesday, November 16, 2016 - 11:58 PM UTC
Any plans to draw up the HEMTT air brake cylinders?
MikeyBugs95
Posted: Thursday, November 17, 2016 - 04:45 AM UTC
Yes the cylinders are still on my design list. And no, I have not forgotten about the Bailey Bridge components either.
MikeyBugs95
Posted: Friday, November 18, 2016 - 03:55 AM UTC
To everyone who ordered a SINCGARS set... Congrats! I just got an email saying they've finished printing and have been shipped!
Posted: Friday, November 18, 2016 - 06:36 AM UTC
Can't wait to hear/see how they look. Be sure to post some pics when you get them.
MikeyBugs95
Posted: Friday, November 18, 2016 - 07:56 AM UTC
Actually I won't be getting my set in yet. Mine went back into pre-production for some reason - some part of it probably broke along the way. It just started production again earlier today.
I hope I can see some of the sets being used in some builds here. I actually don't have too too much of a use for the SINCGARS currently.
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Friday, November 18, 2016 - 08:57 AM UTC
Mike F.Y.I., saw your SINCGARS listed on the Shapeways site a few days ago. Looked real good to me but then the last few days it has not been there. The A/C unit is however been there the whole time.
MikeyBugs95
Posted: Friday, November 18, 2016 - 09:15 AM UTC
The set is still up. It should be the very last item under the 1/35 section when in order of "Most Popular."
165thspc
#521
Posted: Friday, November 18, 2016 - 10:18 AM UTC
Found it when I did a general search for "SINCGARS" but when I looked under "Miniatures/Vehicles/Military/1 35" it was not there. As I say the A/C unit was there but only the older radios showed up.
MikeyBugs95
Posted: Friday, November 18, 2016 - 10:35 AM UTC
I see the problem. I had it originally under the "Other" category in Miniatures. I moved it to Vehicles-Military-1/35.
165thspc
#521
Posted: Friday, November 18, 2016 - 12:56 PM UTC
10-4
__________________________________________________________________________________________________
Minor comment on the A/C unit: The Shapeways caption says the box is hollow which is great. However those two rectangular ducts at the top front of the unit should be opened up into that hollow space, They should appear wide open to the inside of the box rather than plugged just a few inches back from the front.
MikeyBugs95
Posted: Saturday, November 19, 2016 - 06:53 AM UTC
OK, I opened up the front vents. They extend into the hollow space now. I also started on the brake chambers. The front brakes are almost finished.
MikeyBugs95
Posted: Saturday, November 19, 2016 - 11:37 AM UTC
For the brake cylinders, should I include the mounting bolts or do they not matter?
