Sd.Kfz.251/22 Ausf.D finished.
AFV Club Campaign
Posted: Thursday, March 30, 2017 - 12:40 PM UTC
GaryKato
KitMaker: 3,694 posts
Armorama: 2,693 posts
Posted: Thursday, March 30, 2017 - 03:06 PM UTC
Done
Blespooky - 1/350 I-58
brekinapez - Sd.Kfz. 251/20 Ausf. D "Uhu"
ClaytonFromEllijay - M548A1
colinEdm - Nashorn
dcandal - SdKfz 251/20 Ausf. D "Uhu"
eMan - SdKfz 251/22 Ausf D
LinusB - Centurion Mk 5/1 RAAC Vietnam
Namabiiru - FV101 Scorpion
Northern_Lad - M36
Pave-Hawk - Valentine Mk.II
Sean50 - AEC Dorchester ACV
SgtRam - AEC Matador
TacFireGuru - 88mm Flak 18
Thirian24 - M1130 Stryker CV
TMoon - Sd.Kfz. 232
colinEdm - Nashorn
Northern_Lad - M36
TMoon - Sd.Kfz. 232
Ranger74
Tennessee, United States
KitMaker: 1,290 posts
Armorama: 658 posts
Armorama: 658 posts
Posted: Thursday, March 30, 2017 - 05:19 PM UTC
Hello there
I think I'm done with this one. Few little niggles that were my fault not the kit's... all in all quite enjoyable. No real problems (aside form my own limitations)
The ridge from the masking tape is nowhere near as prominent in real life. Might try and fix it but probably just leave it and put it down to experience.
Sean
Sean, That is the ugliest vehicle in this campaign and you did an excellent job of portraying the beast in all its majesty!
Posted: Thursday, March 30, 2017 - 07:12 PM UTC
Lap Man- very nice job, well done!
Sean50
Manche, France
KitMaker: 340 posts
Armorama: 328 posts
KitMaker: 340 posts
Armorama: 328 posts
Posted: Friday, March 31, 2017 - 01:44 PM UTC
One more done! Don't forget to upload a picture to the campaign gallery.
Done, I think...
Clayton and Jeff,
Thanks. appreciate it
She is a (dirty) beast but that's part of the attraction
Sean
GaryKato
Posted: Friday, March 31, 2017 - 06:43 PM UTC
All current finishers have photos in the campaign gallery. The campaign has 7 more days (April 8 ) for a few to finish.
I think we covered the AFV Club line pretty well, from WW2 to modern, types (tanks, armored cars, soft skins, artillery, and our one submarine), and nationalities. Good job, everyone!
For those still finishing, hang in there!
Ranger74
Armorama: 658 posts
Armorama: 658 posts
Posted: Saturday, April 01, 2017 - 06:41 AM UTC
Congrats to all those that finished by the original completion date. Since we received a grace period I did not stay up all night Thursday to finish my YPR-756. I lack just mounting the swim vane and antennae mounts with antennae and some light weathering.
The swim vane is connected to the vehicle by only two hinges, so I tried to secure to engine compartment hatch with glue. Thus the scars on the hatch.The location of the brush guard located near top of the of the vane was questionable. The was a raised line forming a rectangle the size of the brush guard mounting plate where you can see the "scar" just below current location of the brush guard. I could not get the brush guard to line up with the smoke launchers located just above the swim vane. Looking at photos I saw that the brush guard was mounted too low. Looking at the instructions more closely I saw that I should have ignored the raised lines. Luckily I was able to pop off the PE base plate and relocate. Just need to repaint park of the vane and I can then install it.
Ranger74
Armorama: 658 posts
Armorama: 658 posts
Posted: Saturday, April 01, 2017 - 06:51 AM UTC
I had determined to use the kit supplied "rubber-band" tracks as I thought the lack of droop would be hidden by the bottom of the flotation cells mounted on the vehicle sides. I was wrong. The sides of the flotation cells do not cover as much of the suspension as the original swim skirts. What to do? I could try to insert wire pins to enforce the proper droop, but there was not enough room to get a pin vise into space to drill holes for the pins. I could not remove the tracks as I had to clamp the sprockets overnight to keep the too tight tracks from pulling out the sprockets. So, after checking what was visible with flotation cells in place, I came up with shims made from hollow square plastic "pipe" with a couple thin sheets of additional plastic to get right effect. I then painted the shims OD to camoflage the and installed the flotation cells:
Luckily my meds did there job and the model did not go for a short flight before I came up with a solution.
Posted: Saturday, April 01, 2017 - 04:50 PM UTC
Elegant, Jeff. Not sure I would ever have thought of that.
Posted: Saturday, April 01, 2017 - 06:50 PM UTC
Neat solution.
Ranger74
Armorama: 658 posts
Armorama: 658 posts
Posted: Monday, April 03, 2017 - 07:34 PM UTC
I am declaring my YPR-765 completed. I am also, sadly, withdrawing the Medium Recon Vehicle due to issues with painting and lack of time. My wife and I are departing for Massachusetts Thursday morning to attend our grandson's 1st birthday party and won't return until next Monday. Enough excuses, now onto the photos:
I weathered the underside just for the heck of it. I kept wear and tear to the minimum as this vehicles spent more time in the motorpool than in the field. Some silver pencil and aluminum paint for chips and scraps. I also used pastels to add some smoke on the engine and heater exhausts and some Tensacolor wash for fuel spill. The fuel comes fast out of military tankers! Finally, I added like sand colored pastels and removed most with a wide brush to represent more the dust that settles in crevices and seams and only a light overall dusting. The pastels revealed that I should have added another flat clear coat after touch-up painting when I added the flotations cells. Live and learn. I think it will make a good 6-footer.
GaryKato
Posted: Monday, April 03, 2017 - 09:28 PM UTC
I bet your grandson would love a model of a YPR-765! Congrats on finishing the campaign!
Done
colinEdm - Nashorn
Northern_Lad - M36
Ranger74 - YPR765-PRI
TMoon - Sd.Kfz. 232
4 days left.
Done
colinEdm - Nashorn
Northern_Lad - M36
TMoon - Sd.Kfz. 232
4 days left.
Ranger74
Armorama: 658 posts
Armorama: 658 posts
Posted: Tuesday, April 04, 2017 - 05:17 AM UTC
Done
colinEdm - Nashorn
Northern_Lad - M36
TMoon - Sd.Kfz. 232
4 days left.
Gary, Thanks for organizing and moderating this campaugn.
GaryKato
Posted: Tuesday, April 04, 2017 - 06:21 AM UTC
I thought it was high time that AFV Club got some recognition. I wish I could have chosen a better kit myself, but I still got some good out of this. I intend to glue my first (drive sprocket teeth) photo-etch part before the campaign ends.
brekinapez
Georgia, United States
KitMaker: 2,272 posts
Armorama: 1,860 posts
Posted: Tuesday, April 04, 2017 - 08:10 AM UTC
Well, if you ever feel AFV needs some more attention, I'm good for at least seven more runs, maybe a few more depending on what the future brings. I still need a few SdKfz 251/something or others to finish the set.
Posted: Tuesday, April 04, 2017 - 06:55 PM UTC
You've run a great campaign, Gary, looking forward to your next one!
GaryKato
Posted: Wednesday, April 05, 2017 - 04:13 AM UTC
Well the campaign is over for me as I have accomplished my goal. I glued the photo-etch metal drive sprocket teeth onto the inner drive sprockets. Light was beginning to fail so the outer drive sprockets will wait for their teeth later. I had to use a magnifier to get the the alignment holes in the teeth onto the bumps on the wheels. I used a slightly thick CA glue to allow me some time in case of last second alignment disaster. This is my first time with photo-etch parts.
Now to rest and calm my nerves.
Kanguroo
Vietnam
KitMaker: 416 posts
Armorama: 312 posts
KitMaker: 416 posts
Armorama: 312 posts
Posted: Wednesday, April 05, 2017 - 08:10 PM UTC
Posted: Wednesday, April 05, 2017 - 09:25 PM UTC
I love your jeep, K! The painting and detail are fantastic!
It looks like the sergeant is yelling at some private to get another coat of Armor-All on the spare tire pronto before the general arrives!
GaryKato
Posted: Wednesday, April 05, 2017 - 09:54 PM UTC
Great work!
Done
colinEdm - Nashorn
Kanguroo - M38A1 Jeep
Northern_Lad - M36
TMoon - Sd.Kfz. 232
Two more days remaining!
Done
colinEdm - Nashorn
Northern_Lad - M36
TMoon - Sd.Kfz. 232
Kanguroo
Vietnam
KitMaker: 416 posts
Armorama: 312 posts
KitMaker: 416 posts
Armorama: 312 posts
Posted: Thursday, April 06, 2017 - 08:52 AM UTC
Thanks, Mark
K.
pablo_g
Wojewodztwo Slaskie, Poland
KitMaker: 529 posts
Armorama: 500 posts
KitMaker: 529 posts
Armorama: 500 posts
Posted: Friday, April 07, 2017 - 02:40 PM UTC
Hello gentlemen,
I congratulate all the great models, I also managed to finish though was not easy. ;-) Here are the pictures:
Posted: Friday, April 07, 2017 - 02:54 PM UTC
Pawel,
That is an awesome job, as always! Are the markings decals or stencils? I'm curious about the dark spot in the middle of all the 4s.
pablo_g
KitMaker: 529 posts
Armorama: 500 posts
KitMaker: 529 posts
Armorama: 500 posts
Posted: Friday, April 07, 2017 - 03:39 PM UTC
Thanks Mark for kinds words.
It's decals, it's great. I also wondered about those dark spots in the four, was so on decals. My theory is that the original vehicle was repaint, after delivery to africa from European camouflage. The original tactical numbers were left and painted only from the outside without paying attention to the interior of the figures.
GaryKato
Posted: Friday, April 07, 2017 - 07:36 PM UTC
Congratulations on finishing and with such a beautiful build!
Done
colinEdm - Nashorn
Northern_Lad - M36
pablo_g - AEC Dorchester ACV
TMoon - Sd.Kfz. 232
Anyone else still working on their entry out there?
Done
colinEdm - Nashorn
Northern_Lad - M36
TMoon - Sd.Kfz. 232
