I've often wondered that as well............... I know he used this http://www.radioshack.com/product/index.jsp?productId=2102868&cp=&sr=1&origkw=etching&kw=etching&parentPage=search
Which is Ferric chloride
Frag 5 WIP
matt
KitMaker: 5,957 posts
Armorama: 2,956 posts
Posted: Wednesday, November 21, 2007 - 05:58 AM UTC
Boggie
KitMaker: 1,370 posts
Armorama: 1,331 posts
Posted: Wednesday, November 21, 2007 - 08:45 AM UTC
Matt
here is a new latch mechanism. The D ring is now .035mm the original was.030mm so Jeff you can see the difference. Compare the close up of Matte Blacks latch to this to see the added detail. The scapula like piece in behind links to the rod that opens the lower lock. The D ring assembly sits on a cast circular base which the door handle is welded to. The brace off to the right is bolted to the assembly and to the door.
With this kind of detail do you think you could cast it? I know your rifle casts are smaller and more delicate but they don't have the radiating spokes at various depth. If this could be cast then the rest of the doorS are not such a big problem.
Regards
Bill
Regards
Bill
matt
Posted: Wednesday, November 21, 2007 - 02:07 PM UTC
If the latches are realle 3d it might be a slight problem. (But in my opinion nothing a littl "flash" on the part won't fix. It's all a matter of locating the casting block and adding runners (and sometimes sheets) to the part to make them cast easier.
Matt
Matt
seb43
KitMaker: 2,315 posts
Armorama: 2,158 posts
Posted: Wednesday, November 21, 2007 - 03:29 PM UTC
Bill
Well since i moved 2 months ago from Switzerland to Mexico with all the family my modeling stuff are still in the boxes, I hope to be back to business in one month
i will have to finish my M113A3 with the bird cage.
thanks anyway for asking look really cool the new images
Seb
Seb
USArmy2534
KitMaker: 2,716 posts
Armorama: 1,864 posts
Posted: Wednesday, November 21, 2007 - 04:50 PM UTC
Matt
Well since - as an America you know - I'm not familiar with your Canadian money
Cheers. FYI, since its Thanksgiving and with yet another term paper due next week, I'll probably be off the grid until the weekend)
Jeff
Boggie
Posted: Thursday, November 22, 2007 - 01:29 AM UTC
Jeff
I thought about the scale reference as well. The English penny is huge compared to the Canadian, next time I'll use my mm rule. I will replace the older D rings with the newer for all doors. Actually since this door mechanism is much more detailed I'll rebuild the door again and incorporate the development, there is no use going backwards. I may try to cast the mechanism in resin so The bolts are resin from Calibre 45.
http://www.perthmilitarymodelling.com/reviews/tools/calibre35/cal35048.htm
When I saw Ti's amazing Canadian LAV I emailed him to ask what he was using. I found a supply of them at Hannants in England. Have a good Thanksgiving Jeff.
Seb
From Switzerland to Mexico, I guess your skiing days are over! I was really inspired by your FMTV Mothership build a while back, now that was scratch building! I look forward to your new effort from Mexico.
Thanks for commenting, it helps to fine tune the project.
Bill
Seb
Bill
Removed by original poster on 11/23/07 - 10:15:04 (GMT).
seb43
Posted: Thursday, November 22, 2007 - 03:14 PM UTC
Bill
Well my skiing days are definitely over but not my mountaineering days for sure, well i hope
My pinacolada days has just started
Thanks for your kind word on my M1078
I will try to go back to modeling ASAP and I will let you know
Seb
Seb
Boggie
Posted: Wednesday, December 19, 2007 - 04:08 AM UTC
Hi all
I wanted to get this update in before Christmas, this is not the final version. Now that I have these photos taken I can see things that aren't just right and I know there are mistakes. The Mig turret ring is not cemented (gap) in place to make working on it easier, the joystick hasn't been painted nor wired, that'll happen when I install. The clip that holds the M4 barrel kept getting smashed so I took it off until final assembly as well and the handle is cut off at the bottom so I can install the 50mm ammo can that Matte Black's pictures showed holding the smoke grenades. The glass blocks are in the works and will take some time to resolve. Constructive criticism is always welcome.
http://s215.photobucket.com/albums/cc239/writchie_2007/HMMWV/?start=60
I had to remove the images because I couldn't post the pictures directly from Photo Bucket for some reason. Here is the link to the page however until I can fix this.
Bill
Bill
chefchris
KitMaker: 1,544 posts
Armorama: 1,464 posts
Posted: Wednesday, December 19, 2007 - 04:34 AM UTC
WOW~!!
That's some incredible work!
Chris
Chris
Epi
KitMaker: 3,586 posts
Armorama: 2,556 posts
Posted: Wednesday, December 19, 2007 - 04:37 AM UTC
Make me one, make me one!!!!!!!!!!!
Boggie,
Did you happen to make any line drawings of this turret. Looking at it makes me want to do another Hummer.
If I didnt know it was 1/35 scale, I would think it was the real thing.
Boggie,
Frenchy
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Wednesday, December 19, 2007 - 04:42 AM UTC
Very impressive Bill !! (I know, I know - it's not a very constructive comment). I have no real uparmored M1114 in my backyard to compare, but this turret really looks the part...
Keep on the impressive work !
Frenchy
Frenchy
Boggie
Posted: Wednesday, December 19, 2007 - 04:46 AM UTC
Pete
Thanks for the positive feedback and yes I did make line drawings with notes. I'll scan them for you if you'd like?
Regards
Bill
Regards
Bill
Boggie
Posted: Wednesday, December 19, 2007 - 04:49 AM UTC
Frenchy
As always, thanks for all your continuous research it helped to make this happen.
Chris, you are too kind, it'll look better once I get the glass blocks in it and the gun mounted.
Regards
Bill
Regards
Bill
Epi
Posted: Wednesday, December 19, 2007 - 04:51 AM UTC
Oh most definately Boggie. I would like to add it to my reference files just in case I do decide to build another Hummer.
Much appriciated.
Much appriciated.
Boggie
Posted: Wednesday, December 19, 2007 - 05:33 AM UTC
Here ya go
Sorry photo bucket problem
I have other details (if these aren't enough to get you going), just ask.
Bill
Bill
troubble27
KitMaker: 783 posts
Armorama: 637 posts
Posted: Wednesday, December 19, 2007 - 05:48 AM UTC
Baggie,
I agree with Pete. HOLY CRA..... When I saw the first photo of the turret, I was thinking to myself "How did he manage to find a turret "off" of a humvee to photograph???" Man, youve got some serious skills. I swear, I thought it was real. Keep up the great work
Gary
PS - Doors look good too!
Gary
Boggie
Posted: Wednesday, December 19, 2007 - 06:01 AM UTC
USArmy2534
Posted: Wednesday, December 19, 2007 - 06:15 AM UTC
Crap Bill! I'm not sure what's more useful, the line drawings of pictures of the model. Excellent job. Kinda makes me wanna scratch one of those Rhino/Warlock anti-IED devices tonight just to see if I can.
Jeff
Jeff
Epi
Posted: Wednesday, December 19, 2007 - 06:34 AM UTC
OH YEA! Thanks Boggie (BAGGIE)! Gonna save the pics when I get home tonight.
Damn you, know I am defiantely gonna do another Hummer.
Boggie
Posted: Wednesday, December 19, 2007 - 08:10 AM UTC
Jeff
I painted the door for you because you mentioned that you'd only be able to see the details that way, I think you were right though about the weight of the D ring, it needs to be heavier. Between Joe (Mother) you and I building the Rhino we should be able to sort it out, keep measurements though, I look forward to your progress. Thanks for the kind words as well.
Pete,ya it's about time you built another HMMWV, you're almost done the Stryker (I'm almost ready to start mine now). It's looking great bu the way.
I gotta say that it great to be part of this forum, it really inspires me to get on with things.
Cheers all
Bill
Cheers all
Bill
Epi
Posted: Wednesday, December 19, 2007 - 08:37 AM UTC
You know Boggie, i think I'm gonna get in on this group "RHINO" build with you. Mother, and Jeff. I still have that M1114 that I was working on. Maybe this will inspre me to get back on it.
USArmy2534
Posted: Wednesday, December 19, 2007 - 08:40 AM UTC
We need to start calling ourselves the Humvee band. Between myself, Bill, Pete, Gary, 18Bravo, Matteblack, AFV_Rob and a few others...lol
Jeff
Jeff
Boggie
Posted: Wednesday, December 19, 2007 - 09:02 AM UTC
Guys
It sounds like a campaign is in the wind? Who will lead this band of Humvees?Call it the modern HMMWV? Just a thought, I've had far too much coffee today.
Bill
Bill
troubble27
KitMaker: 783 posts
Armorama: 637 posts
Posted: Wednesday, December 19, 2007 - 09:26 AM UTC
Doh! Sorry about the typo Boggie! Let me introduce myself.......
I am
We Todd
Ed
(Say that fast 3 times LOL)
I am
We Todd
Ed
