Scott the water is dark but not of the same darkness everywhere -it's not so much on the left side, I work on a definite sense of the light once more. Though not really see through, I can assure you the light goes through which is what i was after
But well after having more or less worked the colours and all, something is wrong in the shape. Indeed agitated sea does plenty of small waves on the top of the bigger ones (the right side of the pic).
So to get this effect i use acrylic gels like the 1/700 boat guys do
it's very hot outside at the moment, so after a good dozen of minutes the gel begins to set on the surface, then I work on it a bit more, trying to pull out some of the gel, and it's also good to wipe out some brush strokes if any are left.
well, the gel is all very good, but it looks plastic in the end, so I have to coat a good layer of tinted Humbrol clear Quote on the top, and it also does a bit of shadows on that extra texture!
Then back to the painting of the wood: it looks a bit psychedelic like that, but in the end, it *should* work!
today i should be able to end up the paint of those elements.. as well as ending up the sea!
