Ok,
here are a few pics of the work with the tree.
The roots i used are mainly the fine ones as seen in this picture
then comes a rough selection, preselection, more selection and so on.
After that, using reference pictures, you start to mount your tree with suitable pieces, not fearing to cut them as needed. You must use pins to fix it toghether.
The bigger ones are attached with flower wire, but the smaller ones need 0.5 mm drill and small copper wire.
Use super glue to fix them.
First picture , the initial root. Unusable at the end because no rebranching at all. Below the replacement i fixed at the marked place. This one was just big enough for a 0.5 mm hole. (Notice the inserted pin in the other piece (going later in the main branch or trunk)
Now with the new piece
I added probably one or two more pieces to this one before i was satisfied. It is even possible that after a third look i even took it apart again and restarted.
My feeling about the tree and the work to be done changed while building.
Here is a picture showing the pinwork on the trunk (nothing special IMO, but you wanted to see it)
Growing slowly
I am pretty sure that the totality of the branches on top got cut later again and replaced by preassembled entities.
The little one on the left was not good anymore and got discarded completely later.
I am making the bark with self hardening natural clay as soon as i finished a part, this for easier access and manipulation
This looks already a little better
This is the tree again from the other side then the picture shown the day before
I estimate a hundred pins in there!
Here is what i found under one fallen evergreen last week
I hope this helps a bit, it is really not complicated, just a matter of selection and patience, as usual.
@Ygnve , thanks for buyign the book and i am really happy that you like it. Can't ask for more!
Good night
Claude
Well, my hobby cellar for the rough work looks always like that when one modul ais approaching the finishing stage, so don't look to hard :-)
