Congratulations on your win, Radek. If your build got the silver I can't imagine what was necessary to achieve the gold.
@AJB - That first camo colour really turned out great.
I was thinking about trying lower pressure in painting so obviously this supports that direction.
@waltersk - I have found that with these small scale builds it can often be advantageous to paint the smaller detail items separate from the "main bulk" of the vehicle and attach them near the end of the finishing process. The only thing to watch out for is to scrape away a bit of paint from the mating surfaces before gluing.
@firstcircle - YIPPEEE, some of us were right about a Maultier!!!!
The subjects of builds so far in this thread are turning out to be quite unique and diverse. This latest of yours pushes the trend even further along. Your usage of the Bren carrier suspension is positively enlightening. I never would have associated the similarity between the two vehicles track sections. So, are you going to use your new found casting methods from the Mk 1 to cast new tracks for the Maultier?
BTW, while there are some fuel drums from the kit missing from your first submission I shall invoke executive decision making and grant you one point for the tanker truck (see my logic in the section dealing with Jaypee). The Maultier truly makes up for a few errant barrels.
@jaypee - Hmm, two people from the same nation using Bren carrier suspensions to create unique vehicles! Makes the conspiracy advocate in most of us take notice.
Who's to say that your proposed vehicle didn't at least exist on some drafting board.
You have also thrown a monkey-wrench (spanner?) into the rule conundrum. The Bedford is part of a kit but the extent that you propose to modify it cries out for some recognition. On the one hand, you did not meet the rule requirement of providing prior construction sprue pictures for a new build. You state that this build was started during this beginning month so I will take your word on that. The extent of the modifications that you propose, and if they come to fruition, require some consideration. For a "new build" that meets rule requirements, only one model is required. For the completion side one must complete two partial builds to qualify for the ribbon. Looking at this situation mathematically, you get 2 points for a new build and only 1 point for each completion. Therefore to qualify you need a total of two (2) points.
As there was no sprue shots I tend to lean toward the AEC tanker as a completion with one point awarded. However, the proposed work you intend to do on the Bedford goes above and beyond a completion. This is particularly so as you intend to sacrifice a good many parts from a
third kit. Unless there are any vigourous objections I propose to grant you 1 1/2 points for the conversion thereby putting you over the two point requirement.
You sure don't make a campaign leaders job easy, Jaypee!
_____________________________________________
As pour moi! I finally after all the tribulations and deleted expletives have the two assault guns ready for final finishing. The victory over the tracks on the StuG.
The pair together.
The holes for the headlights on the SU-76i are drilled but as luck would have it I can't find the little sprue with the parts.
I am torn whether to finish it as a Russian unit or as a recaptured German one. I've only about a dozen or so pieces left to go on the Stug and then painting can begin. I have four potential colour schemes from the Panzer Colors book to choose from. At present I am leaning toward a dark yellow overall with a sloppy and hastily sprayed red brown mottling.
Jan
