Thanks for dropping in folks and the comments.
Hi Warren,
Re:
Just one thing, it is not Pressed Iron Planking but Pierced Iron Planking
I don't see that mentioned anywhere other than the AA packaging which is for Pressed Steel Planking which as someone pointed out wasn't used on the trucks. I used the Eduard PE parts which I've referred to as sand trays which is how I've alwasy through of them.
Is the Pierced rather than Pressed an Australian thing or just a different use of the language? PSP - Pressed Steel Planking is I believe how it's referred to in the UK although I could be wrong, but that how I've alwasy though of the metal matting you see on runways and around bridges and soft beach heads.
Anyway sand trays works for me, I can't imagine anyone saying get the Pierced Iron Planking off the vehicle lads, but I had heard and used get the sand trays off lads.
Anyway, back to the build. In the hope of getting these finished one day and to expedite things I had order up a set of the Black Dog stowage. The bulk load seems very much in keeping with how the trucks were loaded although it contains jerrycans I didn't see any Flimseys in the load. I though I'd split it between the two trucks with the bulk load going into the RT truck and the remainder of the parts used across both vehicles.
The load it'self needs a bit of clean up on the underside to get a good fit and no provision havs been made for the MG post so I drilled a hole through it to accommodate this which I'll tidy up with some milliput when done.
I hope the truck has strong suspension as the load is quite heavy .
There is a bit of spillage on the underside so this needs tidied up for a good fit.
I drilled a hole through it to accommodate the MG Post.
The bits are currently soaking in some soapy water so I might get a bit of paint on it later.
Al
