Did a bit of work on the raised sides, like you opinion on this. I've see the two raised planks around the top,but would every Breda vehicle have been the same? Reason I ask is obvious from below as I left the metal raised plate on the front and just filled in the gap. I was wondering if this extension plate covered the full length of the front on some vehicles so just left it in place. If it's a big FUBAR I can fix it easily enough and put in a plank. I still need to fill in the interior RHS panel as I assume this would have been smooth like the LHS?
On the internal stowage box at the front of the bed I've seen it extended all the way across, again was this a standard. It's not really an issue as it will be covered by stores but just s general knowledge question.
Did they have ammo ready lockers for the ammo stowage of the Breda or were the ammo cans simply stored at random?
Thoughts welcome.
Thanks
Al
