Hi All,
Slowly and somewhat unsurely we're getting there, having been passed by the tortoise, the hare, and several snails. Captain Williams' Model T is mostly painted, and it's all coming together after a good many wrong turns and pitfalls.
Right side view showing the side tank (Evergreen styrene tube with ends punched from thin styrene sheet with a paper punch) and the spare tire mount. The black cable (.45 mm beading wire) attached to the right front hub goes to the speedometer on the dashboard in front of the driver. Curiously, most Model T speedometer/odometers were mounted on the right, even on left hand drive cars. My guess is that the passenger was expected to do the navigating using the odometer, given the lack of reliable road maps and signage. The hanging cable must have been terribly vulnerable to getting snagged on the wretched roads of the time. The hubs were left unpainted because the fit on the axles is terrible
and the wheels will have to be cemented in place.
Left side view, showing the condenser made from a 2 gallon "flimsy" (cut from styrene rectangular tubing) installed in the cowling. I chose to paint it green because that is the color Shell used for their "flimsies" at the time. The military hadn't yet established standards for such containers, so they came in the supplier's colors.
The hose from the radiator to the condenser is insulation stripped from the same wire used to make the radiator and condenser fittings. The hose connecting the left side of the engine block to the radiator is a piece of solder.
View from above, showing the general layout. A lot of guesswork regarding the colors. It's very hard to interpret colors from a blank and white photo, but in the photo, the Captain's uniform looks very light, like faded khaki, and I based everything on that, some shades lighter, others darker and more towards olive drab. If anyone has other ideas, I'd be glad to hear them.
Right front quarter view, showing the mount (copper wire) for the right side tank. I am still uncertain about what color it should be. In the photo, it is much lighter than everything else, and I was wondering if it might have been unpainted galvanized steel. I haven't a clue as to what it contained. Could be either fuel or water. I can't see any sign of a cap or a tap in the photo, and it is mounted lower than the carburetor on the engine. Model T Fords don't have a fuel pump. The fuel tank is under the seat, and fuel flows by gravity to the carburetor. Since the side tank is secured by a strap, it could be lifted off and the contents poured into the main tank. My guess is that Captain Williams was an experienced desert hand and the tank may have been for water, both for drinking and for the radiator. According to the Australian Light Car Patrols, their condensers only recovered about 75% of the water which boiled over. It's quite possible that there was a similar tank on the left side, but I had only the one right side photo to go on and only built the one tank.
The wheels will be installed next after I do some work on the tires. I'm still working on the figure of Captain Williams. Once he's done, and after adding some straps to the side tank and spare tire mount, plus retouching the paintwork, the flivver will be finished. Hooray!
Dick
