It now looks like this:
I cleaned up and undercut the mount and T&E. Opened up the pass through for the ammo belt,drilled out the barrel extension and then the cooling holes on its' sides. Put a metal guard for the front sight,made a bolt retractor handle and cut the lines where the feed tray goes. I have to clean up the ejector slot on the side as well as the retractor slide hole as I got a little too ambitious when opening them up. I also drilled out the end of the barrel and made a barrel changing handle from brass rod and tube. The barrel will fit right into the barrel extension now. It's not as nice as the K59 or Live Resin versions but it looks fair for a poor mans' solution. Or at least I think so,
I just realized by looking at these pix that I didn't correct the retracting handle and its' slide. The handle should be all the way forward as the gun is firing!! Back to the drawing board.
J
