Got a lot of detail work and weathering done today. I was looking forward to using the water based oils only to discover they were regular oils. Silly relatives. Lifecolor to the rescue. As I suspected, they do make excellent washes. But first things first; I started the heavy wear areas with a sponge application of dark reddish brown, then followed up with some brownish gunmetal. Turned out quite nice if I say so myself, maybe a little too rusty looking for a desert, but it will get toned down with some pigments. Next up was a wash of thinned umber wash from Vallejo to tone down the ivory, then a beige/grey pin wash. Added the drivers glass, bow mg and vision blocks. The transmission unit was weathered and glued in place as was the shell basket. Also added the missing floor plate and glued the mg ammo bags in their bins. A few lighter coats on some of the grey green surfaces to break up the monotony and so on and so forth and such. Rinse, repeat. As mentioned, a filter with pigments still needs to be applied, the bins glued in place and I can close the hull.
I put the turret together, no glue, just to see what's going on. Unsurprisingly, not a whole lot can really be seen, not to mention being tricky to get decent pictures.
Still need a few details in the turret, and then that can be closed up too.
For those interested, I did some preliminary stuff with Shapeways to get a feel for cost and so on. Let's just say that some more work and head scratching is needed. I was surprised how reasonable costs are, but if I did do a proper set, I don't think it would be cheaper than what's available in resin. The floor is looking to be in the $18-20 US range (not including shipping) depending on a few variables and how little the mark up would be. To be honest, I don't think it will be worth doing unless I can figure out how to seriously reduce the cost which is determined by the volume of the design. Minimum thicknesses need to be taken into account and the thicker the walls, the more material, the higher the cost. I'll play with it some more and see what can be done. That's it for today.
Kimmo
