Got on with the suspension today. It feels like one of those cooking shows. Here's some swing arms I had made earlier...
The suspension in the kit is designed to articulate. When I started building, I hadn't the foggiest idea whether this would be going on a base or not, still don't, so I decided to leave the working bits functional. I pre-painted the hard to reach areas once again, layed the hull on its side and was prepared for some foul language and a well fed floor. Neither happened. A pre Christmas miracle! A small dab of glue on the top of the thingy, I love technical terms, and all is good.
Next up, cleaning the tires. As I mentioned earlier, the fit is tight. Very tight. The weird thing is, the tight fit is only a problem on the outer faces of the road wheels. The inner faces are fine as are the spares. I ended up gently shaving the inner rear edge a few times to give it a bit of a bevel. The fit is much better now, I may need a quick pass with a file. Fortunately I only had to do 16 of them, next step will be to give them some wear and tear. Slapped primer in between the wheels and called it a day.
Some of you may be scratching your heads, primer? There is evidence to suggest the inner faces of the wheel pairs were left in primer. There's a fairly well known colour (or colourized) photo of a Pz III coming out of a river in panzer grey. You can quite clearly see the red in between the wheels. Before you say but but but, let me explain my reasoning.
Road wheel pairs appear to have been painted after they were sandwiched together, ie, only the outer faces were painted. This was gleaned from some videos up on youtube, for both Pz IIIs and IVs. It makes perfect sense actually.
The "colour" photo might be colourized. Yes, it might. But why would the artist bother to paint something red on an otherwise grey tank?
So, until someone shows me different, this is how I'll be doing my road wheels for IIIs and IVs.
That's it for now
Kimmo
