I also worked on the test hull. This has now dried 2 days. I used the stiff stipple brush and got some really nice looking worn patches.
Compare to this and you can see what the extra scrubbing did.
I think the process is becoming fairly obvious. The longer you let the paint dry, the better control you have over what sort of effect you can achieve. The only caveat at this point is I don't know how long is too long for letting the paint sit and of course you need to use stiffer tools. So with this info in hand I coated the remaining hull (I also applied more in heavy wear areas and just sort of dry brushed on others) and the sprockets and idlers and will throw some paint on and tackle it hopefully tomorrow. It may not be until Monday, but I should be able to manage.
Kimmo
