Alright time to focus. Let's get'r done.
The E-50 has some paint on it, just need to figure out how to do the toothed idler. Seems to be flat on the inside, been trying something out with a idler from a tamiya Tiger II.
ISU has a bunch of PE work involved so that one's being put on the back burner for now. But I did start something else to get me moving again.
T-54
Tamiya base and Legend conversion
Legend spider road wheels. Purchased T-54 idlers from shapeways, so I'm spared trying to make my own.
Kind of got me excited since this is my first conversion kit and first go at a resin. Man those really thick casting block parts were a real pain to clean up, good thing I have a dremel.
Had to do some repair to the back because of the casting block. Hatches in place and added the grab handle on the commander's copula. The periscopes have clear plastic on them. Looks really nice in person. The gun mantle has the dust cover which I'm sticking with since I like it. I don't see why the in game doesn't have it. Confuses me why some tanks has such and such and other don't.
Dshk in place. Used the kit coax gun from a trumpy T-62. Needs some more things done, and the locator holes for the copula search light need to be filled in.
Kit gun barrel, some styrene tube and a muzzle break from a Trumpy IS-3M. If you want to be picky, the evacuator should be slightly further back and the gun barrel length should be slightly shorter.
Engine deck in place, needs some repair around the back corner. Seems small chunks broker off while I was removing it from the casting block. Fender supports removed and just need to put the finishing touches on the back.
Fender supports in place and a bunch of cutting and sanding along with some brass wire in place.
And this is where I am at right now.
Already starting on the head light. Rounded one up from a Trumpy KV kit and will be using the kit head light guard with some brass rod to make it higher. Splash guard being moved lower, bulges on the fender being removed as per the render.
In game render isn't a straight up 1949 T-54, so some stuff from the kit T-55 is being retained. The convoy lights for one, splash guard needs to be modified. The cut out for the headlight should be smaller since there is only one headlight here. Bunch of AM stuff coming in, like tow cables, indy tracks, etc. All this along with my new air compressor/air brush with the Medium green I plan on using for this build.
