I also did some more test fitting of the windshield/hood/roof. With the roof taped in place I got a better idea of the fit and sequence. The frame goes in first, then the hood. The armoured glass frames won't align with the hinges properly if you do it the other way around. More on that when I get around to gluing it in place. The main frame is quite thin and flexible so care will be needed in aligning and gluing. I was hoping to get the glass frames glued on first to stiffen the part, but that doesn't seem to be a viable option.
Hopefully nobody is being put off getting the kit because of all the dry fitting and fiddling. If you plan on leaving the doors closed, you won't have as much trouble. Because of the modified dash and the extra detail, I created a little more work than might have been necessary. However, do bear in mind that all the hull plates have beveled edges and will need to be test fitted and glued carefully to avoid extra headaches. This is most definitely not a weekend kit in any case and the wealth of detail is worth the extra time and care needed. More tomorrow, knock on wood.
Kimmo
