While we wait for some better photography conditions, I figure now is as good a time as any to go through the "/review" portion of the blog.
First off, the kit itself. This is definitely not a beginner kit, there are places where a seasoned modeler will have their hands full. Detail is generally excellent, some of which is not really apparent until a coat of paint is on. I only found a few minor instances of flash, very few ejector marks to deal with and molding seams were minimal. The plastic is a little on the soft side for my taste and IBG could benefit from switching to a harder plastic to help eliminate warping or damage during clean up on the thinner parts, for example: the nose framing and rear doors.
The engineering could have been better thought out. There were instances of parts that could have easily been combined to reduce the overall parts count, and to make life easier. Fit was generally good, with the exception of the main hull parts due to beveled edges. In fairness, I don't think IBG could have done much else without making the parts a lot thicker. Mounting stubs could be larger in many instances and please, please, please eliminate butt joins!
The instructions were adequate but could use some improvement. Clearer sequences (and illustrations) for the more complicated assemblies and sub-assemblies would be a welcome addition. Colour call outs would be nice too.
The decals are on the extremely thin side, so test a marking you won't use to see how they react. The photo etch provided is a nice addition, bend marks could be added to a few pieces to help the modeler.
Room for improvement:
As mentioned, the detail is quite good, however, some things could be improved. The dashboard for instance has no gauge detail or decals so you have to source them yourself. Additionally, the panel is a wee bit short. The turret weapons have no mounts, so again you will need to figure that one out for yourself. The wheels could benefit from deeper treads. As to the side doors which I modified, I'll give IBG the benefit of the doubt as to accuracy. It may well be that there are examples with narrower doors as provided in the kit. Some stowage would be a nice addition, this seems to be a common complaint with most manufacturers.
All in all, I'd give this kit a 93% rating and recommend it to experienced modelers.
On to the etch sets by Part.
The general detail set (P35-265) provided was not specifically meant to be used with this kit, but rather the other Mk II. I found most of the set still very usable and offers some nice additions. A few of the items provided are, in my opinion, unnecessary regardless of which version of the kit you are building. The molded on visors, antenna mount frame and so on are perfectly adequate and the visors can easily be scratched by the average modeler should you want them in different positions. The armoured grills could have been better thought out, most modelers will find assembling them onerous due to the small spacers needed. The headlight bar assembly, while more in scale, is one of those careful what you wish for items. Plenty of hinges are provided (somewhat strangely attached to the fret) should you want to replace the molded on ones. Sadly, no wire or mention of what diameter wire should be used to form them is included. The instructions were generally adequate, but a clearer sequence or recommended sequence for the grills would have been useful. The tie down straps could also use a little more explanation for those unfamiliar with etch straps and buckles. The set is recommended and I'd give it a 94% rating.
The fender and sand channel set (P35-266) was somewhat of a disappointment. The sand channels look fantastic and bend up nicely with a folding aid. A cross section view would have been helpful to approximate the bend angles. However, the fenders are what lets the set down as a whole. The fenders themselves are nice and bend to shape well. The problem is that the instructions aren't really clear on what how you are supposed to attach them to the kit. There's a thinner strip that runs around the inner edge, but it is unclear if this is supposed to go on top of the fender? Complicating matters is the way IBG molded the fenders in the first place with a narrow stub on the hull. I'm afraid you'll have to scratch your head and proceed as you best see fit. The instructions for this set needs improvement in this regard, further explanation for the additional straps would be good as I noted for the general detail set. I'm really torn about giving this set a rating or recommendation. As is, the fenders aren't really useful additions, so half of the set is really rather wasted in my opinion. But if needs must, recommended with reservations and a 60% rating.
One thing I would like to see Part do, apart from the suggestions above, and as I mentioned in the blog, is to provide another set that covers the missing interior details: stowage frames/rack, commander's seat and a new dashboard.
And thus duties completed, my thanks to IBG/Part/Jadar via Armorama and off to wait for some better photography weather. Thanks to all those who've been watching and chiming in.
Kimmo
