While waiting for paint to dry, which is decidedly yellow looking grrrrrr, I decided to have some fun with the weapons. They are really nice as is, some excellent fine detail on all of them. One problem with the soft plastic means barrels will get bent, so be careful. One other problem is that the Boys and Bren have nothing to mount into the turret with and there's not a whole lot of room to fiddle while dry fitting. Leaving the commander's seat off until everything else is painted and in place would help a fair bit.
Starting with the Bren, the only improvements I made were to redo the front and rear sights, drill out the muzzle and add a simple post mount. I trimmed down the front sight a little, added a sprue for the sight and sides from 5 thou. The rear sight is a slice of wire sheathing. If you peer down the sights, they actually line up and you can imagine yourself squeezing off half a mag! The post mount is stretched sprue with the end flattened and shaped, a notch was cut into the mount on the Bren.
The Boys needed a bit more work. The sights were replaced, the rear needs drilling, and the front was wire sheathing again. The half round thing immediately to the rear of the magazine was removed and a thinner version put in place. A bolt was made from stretched sprue. The muzzle had the small nipple trimmed off and a small piece of drilled out rod was dropped in. The mount is a plausible variation on what standard mounting brackets look like. Happily the front grip was at a perfect angle. The mount is rod with a hole drilled through, sprue inserted and then glued into a drilled hole in the front grip. Two small strips and bolts finish it off.
The Vickers got a new front sight similar to the Bren, a couple of doohickeys that were either missed on the kit or undersized and the elongated thingy on the left hand side got the edges rounded off a bit. A hose mount was added to the cooling jacket from sprue inserted into a drilled hole and then drilled out. In retrospect it should probably be a little lower and angled down more. The squeamish may want to turn away right about now. I sliced the barrel guard off, drilled a hole up to the cooling slots and then pushed, prodded and scratched the openings a little to get them all looking deeper. They are ok as is, except for the slots which aren't perpendicular to the mold, they have slanted fills, if that makes sense. The hole I drilled wasn't really large enough for a clean breakthrough as I had originally hoped, but helped to make the impressions deeper. I also drilled the muzzle. The mount had a hole drilled in part way as IBG has one of their butt joins here, and was glued in position.
A lot of the in progress shots were a little fuzzy, so we'll make due with these and a couple of shots with the weapons primed.
I also spent some time getting mixes right for the camo. I may need to do a base coat mix too as the colour is looking way too yellow for Portland Stone and nowhere near orange enough for Light Stone. Sigh. Anyways, that's it for tonight.
Kimmo
