This is a rebuild of my Panzer IV ausf L from What-If IV. It's built using the old DML/Dragon Panzer IV Late Ausf. J. I liked the sloped hull armor but never liked the scratchbuilt Panther influenced turret. To me, it looks too large.
Kit breakdown...removed the add-on equipment from the hull.
I used a Dremel to cut out the engine deck and turret ring sections. The plan was to move the engine compartment forward and move the fighting compartment back.
Removed the driver and hull gunner hatches. Worked up an engine deck using cardstock, a pair of Panther fan covers and engine hatch.
Replaced the cardstock with styrene and set the engine deck down. The actual layout would change throughout the build.
Casement side panels. In the lower left you can actually see an alternative side panel design. I went through several different designs. I settled on this one because it adheres to the sloped hull sides. To gain more room I extended the fighting compartment beyond the rear of the chassis.
A shot to show the bracing for the panels.
Originally, I had planned on using the Panzer IV gun. I decided to go all-in and used a longer gun. This is the alternative gun that comes with Trumpeter's E-50 tank.
A quick mock-up to check out the gun and casement. The original idea was to have the front corners of the casement angled. I decided to simplify it and just square it off with a slight angle on the front casement plate.
Add commander's hatch. I wanted to use a cast Panther cupola but the casement roof is pretty small. I think the small hatch was leftovers from Dragon's King Tiger with zimm....some of the Jagdtiger bits.
The gun is mounted on a styrene plate. I used shaped styrene for bolts.
Gun added. I left it at a slight depressed angle. I plan on adding a base to accommodate the wacky suspension...like it's moving across rubble. It's difficult to see but I also added a loader's hatch. I went with a set of half-circle hatches. The travel lock is a leftover from Revell's rebox of the ICM Bergepanther.
Added the rear casement plate. The doors are leftovers from the Italerior armored maultier I used for the Hippo. The exhaust had to be reworked to clear the casement. I added styrene extenders. I boxed in the underside of the rear casement overhang and added an angled section to tie it in to the rear.
Add a gun sight. I simply drilled out a hole and added a curved styrene scrap as a rain shield. You can see some additions to the engine deck. The strips are suppose to be shot guards. They also cover the engine deck's seams. Added bolts made from stretched sprue.
A few more additions like tie-downs and gun cleaning rod container. The latter was left over from the Bergepanther. Also note more changes to the engine deck. The driver and hull gunner hatches are actually from the Itaeri Panzer IV I scavenged to use on the Hippo suspension. The figures are posed to relate size.
And with that she is ready for paint. I'm going to stick with a winter/snow camo scheme. I'll probably add a secondary color just to break things up.
