Hello Simon, Thanks for the heads-up. That was my plan, just cement 'em. I won't be rolling it across the carpet.
You still have my attention Al and I am enjoying the prodgress made.
Oh no - that way lies madness!![]()
The good thing is it's pretty dark in there, so you might get away with just a "lump" for the engine cover, without needing to add the driver's station etc. I tested the view on mine, and you really cannot see the ammo stowage in the track frame forward of the 6pdrs (phew!) or the differential at the back, so unless you open the roof hatch or leave the roof off you don't need to build any of the more fiddly stuff! The engine had a sheet-metal cover, so it's a slightly-curved box with three pipes coming out the top - easy enough to scratch.
Good luck! (We'll keep the men in white coats on stand-by)![]()
This link may help Al even though it is a Mk2. I hope to be heading to Bovington Tank Museum on Tuesday, if a Mk 4 is open for viewing, I will get you some images of the guts of the beast.
I think I will also have to add the ammo racks that are at the front of the sponson opening in the track run.
Shouldn't be too difficult, just time consuming.![]()
Al
Quoted TextI think I will also have to add the ammo racks that are at the front of the sponson opening in the track run.
Al
I bet, like me, you're wishing you'd thought of it BEFORE you built up the hull into a box!I'm lovin' the skill and the insanity of this build!
Hi Al,
Nice work on the internals, look forwared to more.
Al![]()
