I buckled down and completed all of the wheels. It actually went pretty fast. There are two types of wheels, 'A' & 'B'.
I thought the parts for the 'A' type would be the more work to clean up than those for the 'B', but it turned out to be the opposite. Takom's instructions tell you not to glue the wheels to the axles. Trying to keep all those wheels and axles in place while lining up the outer hull panels to trap them would (IMHO) lead to true madness. Since I don't care if the wheels rotate, I cemented them to the axles.
Did I mention that there are a lot of them? Those are just half, the ones to be used on just one side. I test fitted a few to show how they inter-leave.
The wheels for the 'A' type fit rather loosely onto their axles. Make sure that the gap between the flanges is even all around. If you don't it may lead to problems where the flanges are overlapped by the 'B' type wheels. You can see that the wheels will be all but invisible once the tracks are in place.
Inspired by a discussion about working with PE parts at a local club meeting last night, I got out my trusty 'Hold & Fold', and added the PE parts to the armored gas tank.
I've used accelerator to speed up the bond when using super-glue. One tip that I picked up during the discussion was to use a toothpick to apply the accelerator to the joint. Never thought of using a toothpick for that, worked like a charm. Also added the PE to the two brackets (Parts E23 & E22) on the inside of the track runs.
I've found a couple of parts that appear to be unused. I can't find them mentioned anywhere in the instructions. Two are plastic, C24, and the other two are tiny, X-shaped, PE parts, TP7. A puzzlement. I'll try to get some more work done today. It's very damp and rainy, so I won't be doing any painting yet. Still have some more to add to the interior. Any comments or questions are welcome, thanks for looking.
Al
